intakes and such
Old Dec 24, 2004 | 11:51 PM
mkiv98's Avatar
Default intakes and such
here is what my engine bay looks like right now.
is it worth it to swap out the short ram for a CAI? does it make that much of a difference? I have a V2 on a DC5 type S so i'm wondering if its "bad" like that is.
also, do you think its true that the short ram gives more low end torque than a CAI?
Old Dec 25, 2004 | 01:49 AM
TrueUntilDeath.com's Avatar
Default Re: intakes and such (mkiv98)
go turbo! lol
there was a thread a few months ago where some guy did dyno test on different types of intakes. surprisingly, certain intakes (brand names) significantly showed an increase in power, and other 2 didnt change much. i cant find that thraed anymore, but i know for a fact that i about read it.
Old Dec 25, 2004 | 07:35 AM
RP215.'s Avatar
Default Re: intakes and such (FrostWhiteDC4)
i believe the shortram is prone to heatsoak. it also has better throttle response. the CAI isn't as prone to heatsoak. you get colder air from it. but it is prone to hydrolocking. thats all i know for now
Old Dec 25, 2004 | 11:07 AM
TurboGS-R's Avatar
Default Re: intakes and such (chopstick407)
The pic looks like DC2. I think that the Cold Air Intake would be better, powerwise. Some people I know prefer the old AEM CAI over the new V2 version.
Old Dec 25, 2004 | 11:23 AM
B18ls*RAYON's Avatar
Default Re: intakes and such (TurboGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">The pic looks like DC2. Some people I know prefer the old AEM CAI over the new V2 version.</TD></TR></TABLE>
Like who? Maybe on a DC5, because the V2 isn't a CAI due to limited engine room, but on a DC2, the V2 is much more ideal. The Bottom half has larger piping making it harder to suck water up (if you should drive through a lake) and produces better numbers over the origanal CAI. The numbers arn't much better going from SRI to CAI to V2, but if your trying to get all you can, go for it.
PS, for you for a clean engine bay.
Old Dec 25, 2004 | 11:46 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkiv98 &raquo;</TD></TR><TR><TD CLASS="quote">here is what my engine bay looks like right now.
No a CAI gives you more low-mid and a shortram you more upper mid-topend, b/c the CAI most of the time chokes on topend. There are exceptions though for CAI with 3" diameter all the way. Do a search this topic has been covered numerous times and there is some good information out there.
Old Dec 25, 2004 | 12:53 PM
kikwear002's Avatar
Very clean engine bay. I want my short ram back. This Cai just doesnt fit me, and the filter came off already.
Old Dec 25, 2004 | 01:02 PM
W.O.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">The pic looks like DC2. I think that the Cold Air Intake would be better, powerwise. Some people I know prefer the old AEM CAI over the new V2 version.</TD></TR></TABLE> silly noob its a DC4,or DB7
Old Dec 25, 2004 | 06:37 PM
mkiv98's Avatar
Default Re: intakes and such (chirpin_3rd)
huh? my car is dc2 (1999 integra LS)
Old Dec 25, 2004 | 06:40 PM
DannyBoy_Db8's Avatar
when i dynoed my car with an aem v2 as opposed to a short ram rs akimoto i gained 10 whp and 5 torque. cleaned up the vtec changeover and it was a used one with a crappy filter on it that had just before i got it hydrolock another gs-r hehe
Old Dec 25, 2004 | 06:49 PM
au-gsr's Avatar
buy an icebox so you get the low end torque of a shrort ram intake, use the Comptech Icebox to kill the heat soak factor as well as giving you the eair of a cold air intake. not only do you get the best of both worlds, but you also gain initial torque and hp because the icebox provide colder deenser air then the short ram in the engine bay.
pretty simple solution for 169.00 plus five for shipping.
if you want one i have a brand new one. pm me
AAron
Old Dec 25, 2004 | 06:51 PM
T Spizzle's Avatar
Intakes are over rated.
Run 3" piping w/ Velocity stack on it.
Old Dec 25, 2004 | 07:01 PM
Default Re: intakes and such (DannyBoy_Db8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DannyBoy_Db8 &raquo;</TD></TR><TR><TD CLASS="quote">when i dynoed my car with an aem v2 as opposed to a short ram rs akimoto i gained 10 whp and 5 torque. cleaned up the vtec changeover and it was a used one with a crappy filter on it that had just before i got it hydrolock another gs-r hehe</TD></TR></TABLE>
hmmm....In tests done AEM only made power in the vtec crossover range and did not help on topend. However every motor is different.
Comptech on the other has proved it self well with its design surprisingly, however the only downfall I see is the the filter element does not filter very well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T Spizzle &raquo;</TD></TR><TR><TD CLASS="quote">Intakes are over rated.
Run 3" piping w/ Velocity stack on it. </TD></TR></TABLE>
There is a thread that is archived on this topic and it makes great topend power if you plan on reving high.
Old Dec 25, 2004 | 09:35 PM
mkiv98's Avatar
Default Re: intakes and such (hybrid_vtec)
you got 10whp + on an NA intake change?
Old Dec 26, 2004 | 03:41 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: (au-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by au-gsr &raquo;</TD></TR><TR><TD CLASS="quote">buy an icebox so you get the low end torque of a shrort ram intake, use the Comptech Icebox to kill the heat soak factor as well as giving you the eair of a cold air intake. not only do you get the best of both worlds, but you also gain initial torque and hp because the icebox provide colder deenser air then the short ram in the engine bay.
AAron</TD></TR></TABLE>
I have the had the Comptech short ram for a while and it made a noticeable difference in power and through my testing on the track it raised my trap about 1.5mph. I just got my Icebox and love it to death, very quiet but still can feel good gains. The Icebox will help you retain that good throttle response that Short Rams have but will give you that cold air you want to be ingested.
Old Dec 26, 2004 | 03:56 AM
DA9RsIntegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkiv98 &raquo;</TD></TR><TR><TD CLASS="quote">huh? my car is dc2 (1999 integra LS)</TD></TR></TABLE>
Can't believe no one said anything yet. DC2 is GSR and Type R only. LS, GS, RS, SE, and whatever is DC4. That is as long as its a 2-door. DB8 or something is 4-door
Old Dec 26, 2004 | 10:58 AM
mkiv98's Avatar
Default Re: intakes and such (DA9RsIntegra)
ohhhh gotcha.
anyone have a link to all the integra notations?
Old Dec 26, 2004 | 01:00 PM
hotsuma23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9RsIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
Can't believe no one said anything yet. DC2 is GSR and Type R only. LS, GS, RS, SE, and whatever is DC4. That is as long as its a 2-door. DB8 or something is 4-door </TD></TR></TABLE>
To add to this:
2 door Gsr or ITR= DC2
4 door Gsr= DB8
2 door LS/GS/SE/RS=DC4
4 door LS= DB7
I dont believe there are any 4 door GS or RS. I may be wrong but as far as I can remember there are none.
soundFX
Oct 25, 2006 12:48 PM
sinister357
Oct 5, 2004 06:57 PM
Accord6Gen
Oct 1, 2004 02:57 AM
even91civic
12
Jul 7, 2004 10:25 AM
chads
Mar 8, 2004 09:27 AM
