Intake Manifold for B18B1 engine...
Old Aug 1, 2005 | 11:21 PM
MansuDC2's Avatar
Default Intake Manifold for B18B1 engine...
Which of these IM's would be good for street/strip performance.
Edelbrock Victor X
Skunk2
BLOX Racing
Glenn
Old Aug 1, 2005 | 11:29 PM
LSvtec03's Avatar
Default Re: Intake Manifold for B18B1 engine... (MansuDC2)
depends on the setup.
stock? none of them will help. they'll only hurt.
Old Aug 2, 2005 | 12:05 AM
JDMxtoMx's Avatar
go with the skunk 2 and get the skunk 2 throttle body too if you can.
Old Aug 2, 2005 | 04:38 AM
rkrone's Avatar
look at the key operating ranges on all of them, example: 7-10k i think is JG and skunk2, if that is what you want, you will loose low and mid power, but if you are going to build up th engine, that would be great for racing
what mods do you have/plan
Old Aug 2, 2005 | 04:45 AM
95lstegman's Avatar
Default Re: Intake Manifold for B18B1 engine... (rkrone)
okay, JG Edelbrock is truly meant for either super-high-revving N/A engines or turbo engines. if you plan on spending a good chunk of time over 7k RPM or getting a turbo kit, get that one.
skunk2 is good for aftermarket cams, headwork, etc. not the god of an intake manifold that the JG, which is good, b/c if you've looked at the JG you'd need one HELL of a sweet N/A motor to make that thing actually make a decent power gain. the Skunk2 will provide decent gains for somebody with maybe just aftermarket cams, or cams and light headwork.
as for the BLOX, it's a basically direct copy of Skunk2.
so pick your poison, buddy.
Old Aug 2, 2005 | 10:18 AM
MansuDC2's Avatar
Default Re: Intake Manifold for B18B1 engine... (95lstegman)
Thanks for the low down, I think I'll be getting me a Blox or Skunk2 with a matching TB. I'm planning on getting the usual, I/H/E, high -flow cat, and cams and some mild head work. Thats about it though, aybe if time allows me, I'll get a Turbo Kit but don't want to deal with the hassles of tuning and managing it so it runs correctly.
Glenn
Old Aug 2, 2005 | 01:29 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MansuDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the low down, I think I'll be getting me a Blox or Skunk2 with a matching TB. I'm planning on getting the usual, I/H/E, high -flow cat, and cams and some mild head work. Thats about it though, aybe if time allows me, I'll get a Turbo Kit but don't want to deal with the hassles of tuning and managing it so it runs correctly.
Glenn</TD></TR></TABLE>
you're going to turbo your car, but not tune or manage it??
good luck with that.
Old Aug 2, 2005 | 03:21 PM
Lord Helmet's Avatar
I want to see a video of the engine go KABOOM!! when you're done driving it around.
Old Aug 2, 2005 | 03:22 PM
rkrone's Avatar
what?!?!?!?!?!?!
do you know what tuning is?!?!..... sorry, but you must get tuning unless you have an endless supply of engines you would like to blow
Old Aug 2, 2005 | 03:33 PM
Danziver's Avatar
Default Re: Intake Manifold for B18B1 engine... (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">depends on the setup.
stock? none of them will help. they'll only hurt.</TD></TR></TABLE>
A skunk2 mani on a stock ls engine is worthless IMO. If you go turbo get a tune soon, you will thank yourself later.
Old Aug 2, 2005 | 03:43 PM
MansuDC2's Avatar
Default Re: Intake Manifold for B18B1 engine... (Danziver)
That didn't come out right, I meant I MIGHT get a Turbo Kit, but probably not because of the cost of tuning and such, sorry about that I know you guys are probably like that guy is an idiot and is gonna end up with a high comp. exlposion, I seen it before w/ my friend's Civic like 4 times already. Sorry about the fuzzy post.. hope this clears it up.
Glenn
Old Aug 2, 2005 | 05:20 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danziver &raquo;</TD></TR><TR><TD CLASS="quote">
A skunk2 mani on a stock ls engine is worthless IMO.</TD></TR></TABLE>
thank you! geez.
monster_c
14
Mar 21, 2012 08:46 PM
turbopanda
Sep 18, 2005 07:56 PM
AL ASPIRATED
Jan 8, 2004 04:42 PM
B00ST2nR
Mar 23, 2002 11:40 PM
GSlowR
Aug 28, 2001 09:58 PM
