Intake Manifold
Old May 22, 2003 | 03:28 PM
B16OnTop's Avatar
Default Intake Manifold
Hey everyone i am interested in one of those intake manifolds with the 40mm individual throttle bodies, you know the one with a throttle body for each cylinder, but i forget the name of them and does anyone know how they run with an LSVTEC setup? (b18b1 block + B16 head + P72 ECU) what all would i need to run this thing and be able to see massive gains... say ive got about 2,000 to play with
Old May 22, 2003 | 03:57 PM
B16OnTop's Avatar
ttt
Old May 22, 2003 | 10:48 PM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: (B16OnTop)
twm and toda has them, and it works best wen tuned correctly with highly built motors.
Old May 23, 2003 | 12:04 AM
10K2HVN's Avatar
Default Re: (NA gs-R 05 C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA gs-R 05 C &raquo;</TD></TR><TR><TD CLASS="quote"> wen tuned correctly with highly built motors.</TD></TR></TABLE>
Old May 23, 2003 | 01:04 AM
Westrock2000's Avatar
Default Re: (10K2HVN)
There called Individual Throttle Bodies. You need a custom fuel managment system, or at least be able to rig the map sensor and all other sensors to work. Due to their physical shape/make-up they make more power at higher RPM's. They can and most likely will cause you to lose some power at low (&lt;4000 RPM), you know the stuff you actually drive around with. They usually start at about $2500 for just ITB assembly. Other than looking cool and sounding loud as fawk, they are not a good idea on a mild street engine.
They are basically for the Engine that has everything else.
EJ8 GSR-T
Dec 19, 2005 07:53 PM
Turbo R
33
Apr 15, 2005 11:28 PM
yeegsr
Sep 14, 2004 09:38 PM
queez
Oct 17, 2003 10:21 AM
