Installing steering wheel?
Old Feb 22, 2010 | 07:16 PM
DC2_2's Avatar
Default Installing steering wheel?
I want to buy either a personal or NRG steering wheel and a NRG quick release, is this all I need to put it in my 2001 gsr?
Old Feb 22, 2010 | 07:39 PM
Apathy47's Avatar
Default Re: Installing steering wheel?
You need a hub. The quick release pieces are for the steering wheel and a hub installs onto the steering column.
this should explain it better:
http://www.getnrg.com/support/?View=entry&EntryID=14
Old Feb 23, 2010 | 06:54 AM
letsdrive's Avatar
also to add, if you have srs airbags, youll need a 2 ohm resistor to put in the drivers airbag plug. this will keep the srs light off and the passenger airbag functioning.
Old Jul 19, 2011 | 06:32 PM
BigDaddyRich's Avatar
Digging this up as I am looking for some tips. I have installed a Quick Release steering and I need to turn off the SRS light in my Dash. Does anyone have any details as to what two wires I have to 2 Ohm resistor? ie: color of wires, pictures?
I have already removed the SRS Wire Tape reel.
**** UPDATE ****
Horn wire and trigger was easily made with some unused TIG welding rod ends.
SRS airbag light was removed by simply unplugging the yellow plug behind the cluster.
Easy Fixes. could have been done better with a resistor, but they work for now.
d4rk13l4de
Feb 26, 2009 08:03 PM
niceprelude
Jan 30, 2009 07:50 AM
b18cEK
Mar 23, 2004 06:48 AM
cannon_man
Feb 17, 2004 03:30 PM
