installing lower tie bar.
Old Aug 18, 2004 | 03:00 PM
Rasta's Avatar
Default installing lower tie bar.
i was looking at the lca bolts and i was wondering if you have to remove exhaust before installing tie bar. Since it looks like the lca bolt on the right side will hit the exhaust if i tried removing it.
Old Aug 18, 2004 | 03:17 PM
genetsang's Avatar
Default Re: installing lower tie bar. (BlitzkriegLs)
no
Old Aug 18, 2004 | 10:47 PM
Dc2 Powered's Avatar
no, what you do is
loosen and remove the 2 inner lower control arm bolts
then remove the two bolts securing the abs senors wire brackets
-remove the abs wheel senor from the wire from the metal brackets by bending back the two tabs holding the wire to the bracket, make sure you dont damage the wire
then you slide the lower control arm colt through the passenger side bracket of the tie bar, install the tie bar into the passenger side of the car and tighten it.
adjust the driver side bracket so the control arm bolts slides easily into the lower control arm.
tighten the bolts that attackes the brackets to the lower tie bar
tighten the jam nut on the rod end
then attack brackets to the inner hole vacated by the factory abs sensor wire
wrap the abs sensor tire to the backside of the backets
! w00t. i learn that from dc sports haha
davidv433
Jun 13, 2007 05:51 PM
sixtodc2
Mar 8, 2006 12:19 PM
RIX982DRLS
Jun 10, 2004 08:43 PM
mickey513
Mar 31, 2003 02:23 PM
JDubya
Sep 2, 2002 04:37 AM
