Installing ITR shift boot! I need help quick!!
Im having trouble installing New ITR shift boot on Gsr. Do I have to take out the whole shift boot console i.e. unbolt the change/lighter slot, and culp holder? Im stuck. I took off the screws from the side I took off the change/lighetr slot, what other screws are holding the shift console together? thanks
is very simple, um trying to take all the screw out once you take it out, flip it over and unscrew the 2 screws and put in the new boot
do i have to unscrew the part where the E-brake is at too, in order to remove the front console where the boot is at? I want to know what other screws are there to take off? The screws holding the cup holders do I unscrew those also?
yes you have to unbolts thats out too, you have to do whateva it takes to flip the console upside so you can unscrew 2 of the bolts
and o yea, if you were to look under your e-brake handle, theres a plastic thing you need to pop it out with a flathead, there will be 2 screw there, so you need to take it out.
it was a bitch trying to get the screws back in where the change holder is, I peeled a good chunk of my skin trying to get my hand in there, that was the harderst part. Everything else i did with ease. thanks again
For future reference... Please go buy yourself a long philips with a magnetic tip screwdriver. That way, you can just stick the screw onto the philips and guide it into the screw hole. This is to avoid any more injuries to yourself.
