injectors
Old May 15, 2005 | 11:25 AM
91lsteg's Avatar
Default injectors
i have 2 harnesses. 1 obd0 and 1 obd1. the engine im using is obd1, but im converting it to obd0. can i cut the harness and use the obd1 dizzy,and obd1 injectors. or do i need a obd0 dizzy, and injectors? thanks for the help
Old May 15, 2005 | 11:27 AM
mr.beeks's Avatar
Default Re: injectors (91lsteg)
obd0 injectors need a resistor box..
in wich I have if you need...
Old May 15, 2005 | 11:32 AM
91lsteg's Avatar
Default Re: injectors (mr.beeks)
hey man i have a pre obd teg and i have a box but i needed to knoe if i can use the injector plugs off the obd1 harness. or just get the obd injectors.
what about the dizzy? there color cordnatingi just cut the obd1 plugs and converted the harness to use the obd1 dizzy is this ok?.
lilsicsoul
Jan 22, 2009 09:31 PM
Homotor
Feb 16, 2008 08:40 AM
hondacivic90zc
Mar 6, 2007 06:02 PM
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
e jay one
Sep 10, 2005 09:15 AM
