Injector O Ring Kit????
Old Feb 6, 2009 | 02:28 PM
Bsharpe's Avatar
Default Injector O Ring Kit????
Where Do i Buy Them? I need one ASAP. Do the stock kits fit bigger cc injectors? Thanks Brent
Old Feb 6, 2009 | 02:53 PM
Jimmy's Avatar
Global Moderator
Default Re: Injector O Ring Kit????
No most likely the stock kits will not fit bigger injectors.. you will likely need to trim them.. with whatever you choose.. I prefer a dremel.. it's the easiest way.
You need to go to napa to get the seal kit.. if there is one around your location..
Here is a link with pic's for reference
http://www.homemadeturbo.com/tech_pr...ors/index.html
Bsharpe, always try searching before posting.. this has been covered numerous times
Old Feb 6, 2009 | 03:36 PM
ruffrhyder's Avatar
Haven't you seen what's been plastered on top of the page for the last day or so? Search is down, again
Old Feb 6, 2009 | 04:18 PM
Jimmy's Avatar
Global Moderator
It says it's down, but it still pulls results.. he could of atleast put forth the effort.. then came back and said.. eeh search doesn't work..
It's okay.. I help anyone
Old Feb 6, 2009 | 04:34 PM
Bsharpe's Avatar
What are the green rings for? The big ones
Boost LI
Aug 15, 2009 10:22 AM
accord_raffi
May 17, 2008 06:09 PM
eytab
Aug 17, 2006 12:03 AM
tegon-gsr
Sep 24, 2004 07:50 PM
