Increase displacment
Old Nov 27, 2001 | 03:42 AM
integra81's Avatar
New User
Default Increase displacment
i am about to rebuild my 94 ls engine because it has 120k miles on it. I am puting higher compression pistons, titanium vavles and valve springs. I am planing on resleeving it instead of boaring it out. Is it possible to put a bigger sleeve in the block instead of boaring out the new one? If so what size? and what sized pistons? im not new to the whole integra thing. True i am olny 17 but i know alot about tegs. I am new to the whole engine rebuild so if you could put your comments in Laymans terms that would help out.
Old Nov 30, 2001 | 03:19 AM
integra81's Avatar
New User
Default Re: Increase displacment (integra81)
anyone??
Old Nov 30, 2001 | 09:49 AM
FSTASNTZ's Avatar
They do make different sized sleeves. I beleive they go all the way up to 85 or 86 MM...
Jason
Old Nov 30, 2001 | 02:30 PM
integra81's Avatar
New User
anyone recomend a manufacturer for sleeves or pistons ??
Old Nov 30, 2001 | 04:02 PM
Evil DOHC's Avatar
Darton sleves or Benson sleeves have been around for a long time. Consult a machine shop before ordering though, depending on your application and such. By getting new sleeves u are boring out the motor to the mm that u want. Also u have to get pistons to match the sleeves and rings.
EVIL
Old Dec 2, 2001 | 10:01 PM
Vtec integra's Avatar
GODZILLA SLEEVES AND 85MM PISTONS
Old Dec 3, 2001 | 02:23 PM
Endless's Avatar
If you're going to rebuild and resleeve, you might want to consider a B20 block. It has very strong sleeves and an 84 mm bore for some nice low end. You can pick up a long lbock for around $1000
q8delsol
Nov 13, 2007 05:09 PM
yz125rider21
10
Feb 5, 2006 12:40 AM
fullracegsr
Feb 23, 2004 05:58 PM
integra81
Nov 30, 2001 02:39 PM
integra81
Nov 30, 2001 03:18 AM
