im stumped!
Old Dec 13, 2004 | 11:38 AM
EKB18BPR3's Avatar
Default im stumped!
after installing CP 9:1 pistons, eagle rods, acl rings, new head gasket, 92 integra head...my car wont start. (check my sig for all the specs) I turn the key and i hear my fuel pump prime, turn a little more and it cranks but wont fire up.
i have compression 150-150-150-150 (remember i have low compression pistons)
i have spark
i have fuel to the rail
is it possible to have NOT ENOUGH spark? could u have spark and still not fire up? ive checked everything...im puzzled?! im in the process of getitng a fuel pressure gauge but until then what would be the culprit? the only thing i havent checked are my fuses but which ones would i check?
Old Dec 13, 2004 | 02:37 PM
EKB18BPR3's Avatar
Default Re: im stumped! (98B00STED)
no body knows or has suggestions?
Old Dec 14, 2004 | 04:13 AM
JimBlake's Avatar
After cranking for a little while, pull the spark plugs & see if they're wet with fuel. Just 'cause you have fuel in the rail doesn't mean the injectors are firing...
Old Dec 14, 2004 | 06:11 AM
Honda Hick's Avatar
Default Re: im stumped! (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">After cranking for a little while, pull the spark plugs & see if they're wet with fuel. Just 'cause you have fuel in the rail doesn't mean the injectors are firing...
I agree. You may have fuel in your rail, but the injectors might not be working for some reason. Did you make any changes to your fuel system, maybe injectors because you are going F/I?
Old Dec 14, 2004 | 11:17 AM
EKB18BPR3's Avatar
i suspected that but the likely chance of all the injectors going bad at the same time? i will check though.
anybody else?
Old Dec 14, 2004 | 11:23 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">
anybody else?</TD></TR></TABLE>
Get the fuel pressure gauge. Someone recently had a problem like yours, turns out there wasn't enough fuel pressure, the pump was shot.
Also check the firing order of the plugs/wires, if it is incorrect, it will not start.
Old Dec 14, 2004 | 11:27 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">i suspected that but the likely chance of all the injectors going bad at the same time?</TD></TR></TABLE>All injectors are supplied with power, full time. The ECU closes the ground side of the circuit to fire each injector. A bad connection in the (+) side of the circuit would take out all the injectors together...
d16z6civic811
Dec 7, 2010 07:06 PM
Dave_Dc2
Mar 14, 2009 09:05 PM
Morasso
30
Feb 7, 2008 12:00 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
temp
15
Jul 6, 2004 08:07 PM
