ignition timing
Old Oct 4, 2007 | 10:41 PM
soon2bdropped's Avatar
Default ignition timing
alright when u move the dizzy cap all ur doing is moving the cap away from the rotor soit can hit the contact point at a later or sooner time right?
also when u retard the timing what being happen.. does the car idle low.. so when the piston comes up on compression it doesn't ignite until its going down?
installed new dizzy **** is giving me problems.
also how do i use timing light and whats the reccommeneded timing for a 94 gsr thanks..
Old Oct 4, 2007 | 11:52 PM
SoTexDC2's Avatar
The proper ignition timing is between 16 - 18 degrees BTDC (before top dead center).
When you move the distributor, you are changing the point at which the spark plug fires, which alters when the combustion process starts.
Yes, this will have a direct effect on idle. You must "jump" the service connector behind the glove box, to keep the ECU from altering your ignition timing.
If your going to continue to work on your car, I strongly suggest getting yourself a HELMS Manual, all of this is covered in there.
I'm lazy and I don't feel like explaining every last detail, so check out this articles:
Setting/Advancing ignition timing -
http://www.team-integra.net/se...ID=60
Understanding the ignition events -
http://www.team-integra.net/se...D=235
Old Oct 5, 2007 | 03:29 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ignition timing (soon2bdropped)
Make sure that the engine is warm and to jump the service connector before setting the timing.
http://www.c-speedracing.com/h...g.php
Old Oct 8, 2007 | 03:47 PM
Default Re: ignition timing (Dogginator)
soi when u adjust it ur not moving the rotor.. ur moving the cap away from the rotor? is thats whats being done?
Old Oct 8, 2007 | 03:58 PM
SoTexDC2's Avatar
Precisely.
mwwtx
Feb 10, 2010 04:26 PM
eg grom
Jun 25, 2009 09:27 PM
hondapwr
Jan 13, 2006 06:58 AM
Attoir
Mar 18, 2004 01:25 PM
RTW DC2R
Mar 9, 2004 09:09 AM
