ignition degree.
Old Mar 31, 2005 | 01:45 PM
projectTeG's Avatar
Default ignition degree.
i've been pondering this for awhile, how do you get the degree of the timing. for example someone says my timing is about 16 degrees, how do you get that????
Old Mar 31, 2005 | 01:58 PM
Padawan's Avatar
Darth ModerVader
Default Re: ignition degree. (projectTeG)
You use a timing gun to set the timing. If it's a standard gun, you'll only be able to exactly set the timing to 14, 16 or 18 degress BTDC (since these are the three lines on the crank pulley). If you have an adjustable advance timing gun, you can accurately adjust it to any setting you want.
Old Mar 31, 2005 | 02:18 PM
projectTeG's Avatar
Default Re: ignition degree. (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">You use a timing gun to set the timing. If it's a standard gun, you'll only be able to exactly set the timing to 14, 16 or 18 degress BTDC (since these are the three lines on the crank pulley). If you have an adjustable advance timing gun, you can accurately adjust it to any setting you want. </TD></TR></TABLE>
k...thanks so the 3 marks on the pulley signify the degree, so the white ones are 14 and 18 and the red ones 16 right???? lol, that question has finnaly been put to rest
Old Mar 31, 2005 | 04:22 PM
95lstegman's Avatar
also there's a white mark on the pulley for right on TDC. this is so you can use an ignition advance analyzer. i have one. mwahahahahaha
Old Mar 31, 2005 | 05:05 PM
r3v's Avatar
r3v
Default Re: ignition degree. (95lstegman)
heres an idea of how the ignition timing gun looks like.
Also, theyre adjusted by the distributor.
OR if you want to degree a cam from TDC. You can use this.
Old Mar 31, 2005 | 05:17 PM
projectTeG's Avatar
Default Re: ignition degree. (r3v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v &raquo;</TD></TR><TR><TD CLASS="quote">heres an idea of how the ignition timing gun looks like.
i know how the timing gun looks, i was just wondering how ppl got the degrees, not how to time the car, thx though
miksew
Aug 12, 2006 06:26 PM
JDMTurboCivic11
May 1, 2005 08:32 PM
bazookatooth
Apr 23, 2005 11:56 PM
powerfulperformance
Oct 20, 2003 04:58 AM
dubnine
Sep 16, 2002 01:35 PM
