idling to high??
Old Nov 30, 2007 | 11:00 AM
DAJay93's Avatar
Default idling to high??
why would this be? =\ HELP!
Old Nov 30, 2007 | 11:46 AM
AWD Terror's Avatar
Default Re: idling to high?? (DAJay93)
Throttle cable too tight.
Idle screw needing adjusted.
High idle being stuck.
Car not warming up.
Where is it idling at?
Old Nov 30, 2007 | 02:28 PM
God-Driven's Avatar
all the above or a vaccum leak
more likely the cable or the screw to adjust the idle are the ones to check first.
Old Nov 30, 2007 | 03:00 PM
Smokinsax's Avatar
The Boot
is the idle surging or at a constant rpm?
Old Nov 30, 2007 | 06:06 PM
DAJay93's Avatar
it idles a lil over 1000 rpm and sometimes it would move up and down from 1000rpm to a lil under 1000rpm
Old Nov 30, 2007 | 08:19 PM
red01teg's Avatar
try bleeding your coolant system
Old Nov 30, 2007 | 11:40 PM
HB_spinout's Avatar
Default Re: idling to high?? (red01teg)
my idles too low, almost dies
b20bFourDoorCivicLX
Aug 8, 2012 09:58 PM
Arthas
Mar 14, 2010 09:08 PM
SAfire
Jan 25, 2009 11:51 PM
PINKS
May 29, 2006 10:26 PM
headhunter
Aug 18, 2003 08:14 PM
