idle problem
Old Feb 17, 2003 | 10:32 PM
NightmareApex's Avatar
Default idle problem
HEy all, I have a serious Idling problem and wanted to know if anyone went threw anything sim.. and wanted to know how they fixed etc. My car idles from 1k-2.5k really fast, and this is the 4th weak that ive had to deal with it and its really anoying, people think im reving on them at lights and cops like give me the evil eye and such, Its not my cams becuz it does it when its cold, and I thought it was the IAC valve but I just got a new one and nothing changed, I am going to replace all of my vacume hoses tomorrow, and im a see what happens, but does anyone have any clue as to what else may cause this bull ****. I hope its not a bent valve(knock on wood).
Old Feb 17, 2003 | 10:40 PM
95gsr's Avatar
Default Re: idle problem (NightmareApex)
ok i have the same problem i found this out if you take out your intake. and look in the throttle body. you will see a 1/4 inch hole on the bottom turn the car on and stick your finger so you plug the hole and the car will idle perfect
Luis
Old Feb 18, 2003 | 01:48 AM
XenonDepot's Avatar
Default Re: idle problem (95gsr)
I had a similar problem in my previous honda. I believe it was either the oxygen sensor (Is your engine light on)? Or your throttle position sensor. One way or another, I took it to Honda, they adjusted something and it was fine....
Old Feb 18, 2003 | 01:52 AM
tbrocato's Avatar
My brother has a 240sx and had the same problem. It was something with the intake manifold. So dont know if this might help u.
Old Feb 18, 2003 | 04:18 AM
IC x Prince's Avatar
New User
Default Re: idle problem (tbrocato)
this is called surging....it happens when your TPS is not with ine specs...just adjust it and it will go back to normal.
Old Feb 18, 2003 | 05:53 AM
95gsr's Avatar
Default Re: idle problem (UltraPrince)
how do you adjust the tps
Old Feb 18, 2003 | 07:31 AM
Russ713's Avatar
dAng!
really ,, how?
Old Feb 18, 2003 | 08:09 AM
yeah im not sure on how to "adjust" the tps, can anyone help with that?
and I have not check engine light, I pluged that hole in the throttle body like the first response suggested, and I got the engine to shut up long enough for me to hear a broken valve rattling around : (
[Modified by NightmareApex, 5:11 PM 2/18/2003]
Old Feb 18, 2003 | 08:45 AM
New User
well i sent my TB to JG...(donne before) and they modified it so I could. but you can do it your self...it's not easy, you have to remove the TB...look at he TPS...there are 2 screw looking things. without the head (i guess honda didn't want you messing with it) and cut 2 grooves in it so you can use a flat blade to back the screws out. then i would replace the scres with regular ones...you will then find that it moves...leave it kinda loose. put it back on the car and start it up. you can adjust it then and the surging will stop. like i said...not for non mechanical people, but that will fix it...good luck guys.
Old Feb 19, 2003 | 08:49 AM
thx ill try it
Old Feb 19, 2003 | 08:57 AM
stumpyf4's Avatar
Could be the TPS or the idle air control valve, the hole that in the bottom of the throttle body. Get a helms manual, it as a good diagnostic procedure.
Marty.
Old Feb 19, 2003 | 10:01 AM
Ok so far its not the TPS, MAP, IAC, and im pretty sure its not a vacume, and I still dont have a clue to what it is.
[Modified by NightmareApex, 7:04 PM 2/19/2003]
Old Feb 22, 2003 | 11:11 PM
lshybrid195's Avatar
i had the same problem wit my b16 it waz annoyin as hell and then i found out it waz my coolant temperature sensor under my throttle body and once i adjusted it it stop idle up and down
Old Feb 23, 2003 | 10:05 PM
Default Re: idle problem (lshybrid195)
hmmmm that actually might be it, can you plz go into more detail about how you fixed it, I believe my ecu threw that code, so that could be it
nonamedude
Apr 3, 2009 09:29 AM
chhonda150
May 4, 2008 05:06 PM
frankenstienEk
Jan 10, 2006 10:37 AM
FAWKeveryb0dy
11
Nov 6, 2005 11:47 AM
rice a roni
12
May 24, 2005 12:31 PM
