idle problem
Old May 17, 2005 | 01:47 PM
rdeezy25's Avatar
Default idle problem
My idle jumps up and down when I start my car when the engine is cold. Goes from like 1000 rpm to 3000 rpm for like 2 seconds over and over for about 3 minutes til warm. I heard it could be the idle sensor or whatever its called but noone knows for sure. Makes a good looking car look bad, you know what I mean. HELP!!!!!
Old May 17, 2005 | 01:55 PM
DAguyLS's Avatar
Default Re: idle problem (rdeezy25)
i know on my civic i had the same problem. it's the IACV....idle air control valve. and the FITV controlls idle after the car has warmed up. thats Fast Idle Thermo Valve.
i think this is correct, i may have the two switched around. not positive. but this should help you in searching around htech to find others with the same problem
stuckinmud
Aug 14, 2009 08:32 AM
Thatssojdm
Aug 5, 2008 07:59 PM
bob16ost
Feb 10, 2004 11:41 AM
SLOAZZ95
Nov 5, 2003 04:42 PM
diLUDEd
Aug 22, 2002 10:08 PM
