idle and low throttle problems v2
Old May 9, 2003 | 10:28 AM
Rob Dizzle's Avatar
Default idle and low throttle problems v2
I thought my problems were from an IAC vavle that went bad. But its not.
My symptoms:
-rough idle
-when going from zero to light throttle (say from a stop) there is a hesitation where changes in throttle do not change power output. If I go from 5% to 12% the car will act like nothing has happended. when I dip in more to the gas then it will start accelerating.
I still might think my IAC valve (even though I just swapped anew one) is bad. When I did the vacuum test by sticking my finger over the top of the 2 holes there still is a strong vacuum after the car has been driven and is above the ~130 degree water temp mark that the helms specifies for the iac to stop or have low vacuum pressure.
I can upload a hondata datalogging session I did with my car at idle.
I will have my timing checked later today
any guesses?
Old May 9, 2003 | 10:50 AM
Sleeper's Avatar
Default Re: idle and low throttle problems v2 (Bob-DC2)
Is there any difference in pedal feel to get you past that 12% throttle? Like a small sticking point?
Old May 9, 2003 | 12:20 PM
Mr.Integra's Avatar
i'd guess iac valve.. but you already replaced it with a new one
u'd get a better answer in tech
freddy chavez
Apr 8, 2013 07:40 AM
pcguy760
Mar 21, 2011 11:11 PM
neldogg
Nov 17, 2007 03:52 PM
ATS*Mark
12
Dec 22, 2005 07:14 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
