I need some help.
Old Aug 20, 2005 | 10:00 AM
Rajin's Avatar
Default I need some help.
Alright guys, I just replaced my old very damaged spark plug wires with a new set.
With my old set the RPM would flux (rise and fall in idle range). Well, before this new set I had a miss, that was pretty obvious, with the new set, it will miss VERY rarely, yet still happens, which doesn't make me happy at all. Along with this, my oil light will display a couple secs longer than my others lights on a cold start (usually 3-5 seconds longer) and Its beginning to bother me, I want to catch the problems now remedy them and get it back to top condition.
Thanks for any input.
Old Aug 20, 2005 | 10:06 AM
Rajin's Avatar
Default Re: I need some help. (Rajin)
Bump
Old Aug 20, 2005 | 10:13 AM
DAguyLS's Avatar
give us more info
miles and whatnot
Old Aug 20, 2005 | 10:14 AM
Rajin's Avatar
Default Re: (DAguyLS)
177950
Rebuilt on 175000
He just didn't replace the minor things and its aggravating me.
Old Aug 20, 2005 | 10:18 AM
DAguyLS's Avatar
I know on my EG I had the same problem with the idle surging and it was the IACV....idle air control valve
Is this happening when you first start it up and it's cold, or after it warms up?
If it's happening after it warms up it would be the FITV....fast idle thermo valve.
Old Aug 20, 2005 | 10:19 AM
DAguyLS's Avatar
And with as many miles as you have it very well could be a clogged IACV, which can be cleaned.
Rajin's Avatar
Default Re: (Rajin)
Alright, that helps, I'll try cleaning, its running a lil hot.
Old Aug 20, 2005 | 10:21 AM
Rajin's Avatar
Default Re: (Rajin)
Bump, other opinions?
Old Aug 20, 2005 | 11:30 AM
Rajin's Avatar
Default Re: (Rajin)
Bump
mlee19841
Honda Civic (2001 - 2005)
May 1, 2015 02:11 PM
termite1r
13
Feb 2, 2014 12:54 PM
werteg
Jun 3, 2012 07:25 AM
rob260
Apr 2, 2006 08:11 AM
