i need a code look up
Old Mar 9, 2004 | 11:52 AM
whoisbrandon's Avatar
Default i need a code look up
hi i was wondering if any could look up a code my car is thowing
when i turn the key the motor light stays on for about 4 secs then blinks 10 times and turns off can any1 please tell me what this means
Old Mar 9, 2004 | 11:57 AM
94civicEX's Avatar
That's just it getting your attention.
You're going to need to actually check the code.
Old Mar 9, 2004 | 12:06 PM
purplegsr's Avatar
Default Re: i need a code look up (whoisbrandon)
It's not throwing a code, that is the normal cycle on startup. If the CEL stays on after that period, than you will have check your ECU (on your passenger side kickboard) for a series of blinking lights. What you described in your post is standard operating procedure, you only have to worry if any lights stay on (i.e. battery, engine, srs, abs, etc etc etc) - Unless I am misreading your post, which happens to me frequently. Good luck.
vstone
Jun 1, 2010 09:29 PM
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
djcue_530
Mar 15, 2007 08:53 AM
Fatty_1775
Jul 25, 2003 09:57 PM
andrewasf77
Feb 13, 2003 02:34 PM
