hydrolocked
Old Apr 17, 2007 | 03:36 PM
kapitalc's Avatar
Default hydrolocked
as everyone on the east coast is well aware of we had a ton of rain this weekend...anyways unfortunately i was out running errands in the rain and long story short ended up going through a puddle that was much deeper than i couldve ever imagined...and the motor died out...i opened the intake box and also removed the tube from the throttle body only to see water run out... so my question was is there any solution for a hydrolocked motor that doesnt include rebuilding...any input would be appreciated thank you
Old Apr 17, 2007 | 03:38 PM
Sam92Teg's Avatar
Default Re: hydrolocked (kapitalc)
Yes, pull your spark plugs out and turn the engine over. This will shoot the water out of your cylinders. Then change your oil and finally, try to start the engine. Hope that you don't hear a knock.
Old Apr 17, 2007 | 03:40 PM
kapitalc's Avatar
thanks...
Old Apr 21, 2007 | 10:48 AM
kapitalc's Avatar
i took out the plugs and tried to turn the motor over and all i get is one click sound then nothing, ive tested the starter and it still is good so any ideas? thansk
Old Apr 21, 2007 | 06:14 PM
Sam92Teg's Avatar
Default Re: (kapitalc)
Keep the plugs out and turn the crank over counter clockwise with the crank pulley bolt. If it doesn't spin, then you need to drop the oil pan and have a look.
Old Apr 21, 2007 | 06:39 PM
stuie08's Avatar
ok, you have insurance, and if you have a sri or cai take it off out and put the stock air box in, call you insurance, and they will pay for it.
masterquo
Other Make Vehicles
Oct 28, 2014 05:54 PM
EF8DayDreamer
Jan 18, 2012 10:12 PM
2hondas_noluck
May 18, 2011 09:13 AM
sw96
14
Nov 8, 2009 11:05 PM
See Are X
Nov 9, 2003 09:09 PM
