HX wheels
Old Oct 9, 2006 | 05:59 AM
EGdriva's Avatar
Banned
Default HX wheels
I am purchasing a set of HX wheels for temp use until I get me some Rota C8's or C10's.
My question is will they fit perfect w/ spacers and or a lil grinding of my caliper.
Because, I test fitted one wheel and it rubbed a bit. But, I'm determined to get these to work. B/c for the time being tese look way better than my stock LS swirlies.
Old Oct 9, 2006 | 06:03 AM
loopedR6's Avatar
Default Re: HX wheels (EGdriva)
dont go grinding on your calipers, thats a bad idea for sure, spacers are actually a bad idea too because with the wheel sitting away from the hub all of the weight and torque will then be applied to the lugs. just get yourself some different wheels
Old Oct 9, 2006 | 06:07 AM
EGdriva's Avatar
Banned
its only temp. can it do damage to my lug. or anything like that.
Old Oct 9, 2006 | 07:12 AM
reno96teg's Avatar
Default Re: (EGdriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGdriva &raquo;</TD></TR><TR><TD CLASS="quote">its only temp. can it do damage to my lug. or anything like that.</TD></TR></TABLE>
why even risk it? and if you're eventually going to get the rotas, why even bother wasting the money?
Old Oct 9, 2006 | 09:09 AM
tasco's Avatar
Default Re: HX wheels (loopedR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loopedR6 &raquo;</TD></TR><TR><TD CLASS="quote">dont go grinding on your calipers, thats a bad idea for sure </TD></TR></TABLE>
how much of the caliper would have to be shaved off. if it wasn't much i don't see why it would hurt anything.
Old Oct 9, 2006 | 12:29 PM
EGdriva's Avatar
Banned
It barely rubbed. I could spin them. But, not freely.
Old Oct 9, 2006 | 01:04 PM
J Money's Avatar
It's not a big deal to grind down the caliper. You have to grind down about .20 in order to get the wheels to fit without rubbing. I've been running ground calipers and HX's for the last 15,000 miles with no problems.
Old Oct 9, 2006 | 05:48 PM
EGdriva's Avatar
Banned
Default Re: (J Money)
you got some pics J money.
Old Oct 9, 2006 | 07:23 PM
mrdeadman's Avatar
They let me pick
I would just save the money and buy real wheels... not temporary ones. It's a waste of cash. Not all of us are "ballers"
Old Oct 9, 2006 | 07:53 PM
EGdriva's Avatar
Banned
Default Re: HX wheels (mrdeadman)
well i actually like these. and, next wheel purchase will be in the spring or summer. so, i will go ahead n get them. i just want the outside to look ok. being that im only doin engine mods for a while.
Old Oct 9, 2006 | 07:55 PM
J Money's Avatar
Don't let them hold you back from getting the wheels. They are lightweight, look great, and are cheap. I found a DIY article on how to fit HX wheels on a DA integra but now I can't find it. If you look around g2ic.com you can probably find it. Good luck.
Modified by J Money at 2:00 AM 10/11/2006
Old Oct 10, 2006 | 06:03 AM
EGdriva's Avatar
Banned
Default Re: HX wheels (J Money)
I've looked thru the articles on G2IC.com but, I can't find anything on hx wheels.
Old Oct 10, 2006 | 05:01 PM
J Money's Avatar
There really isn't anything to it. Get a really powerful grinder, and grind on the outside of the caliper until you can put the wheel on there and spin it without rubbing. Make sure to round the edges off a little more to fit the shape of the wheel. You need to get a real grinder though, a dremel will take way too long.
Old Oct 11, 2006 | 04:58 AM
EGdriva's Avatar
Banned
yea, i have a grinder. its like 35,000rpm I think. It's my dads, Ive always used it to cut down my bike handklebar ends. Is this grinder good enough.
Old Oct 11, 2006 | 05:35 AM
Solscud007's Avatar
just use a spacer. and dont go racing.
Old Oct 11, 2006 | 08:29 AM
mrdeadman's Avatar
They let me pick
Default Re: HX wheels (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">just use a spacer. and dont go racing.</TD></TR></TABLE>
Grinding your calipers is not that bad.
Old Oct 11, 2006 | 09:45 AM
6doorsentra's Avatar
dont do 13 in rims, if anything is rubbing your ****** it up..dont be a dumb ***...
Old Oct 11, 2006 | 09:53 AM
HONDA RR's Avatar
It might hit the calipers .
Old Oct 11, 2006 | 09:54 AM
j87w's Avatar
Default Re: (6doorsentra)
QUOTE=6doorsentra]dont do 13 in rims, if anything is rubbing your ****** it up..dont be a dumb ***...[/QUOTE]
HX Wheels are actually 14's
Old Oct 11, 2006 | 10:01 AM
SL0-hatch's Avatar
Would these rims fit without modification to a DC2. I was planning to run at the track with them on, becuase one of my boys has them. but didn't know that there might be some clearance problems.
Old Oct 11, 2006 | 10:03 AM
Micha's Avatar
FAILWGN
Default Re: HX wheels (98IntegraGSRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98IntegraGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">Would these rims fit without modification to a DC2. I was planning to run at the track with them on, becuase one of my boys has them. but didn't know that there might be some clearance problems.</TD></TR></TABLE>
nope. not on the front.
Old Oct 11, 2006 | 05:00 PM
gtec8285's Avatar
hx wheels are ok with the car as long as you have the right size of spacer because i have them on my DA and it doesnt rub or anything
Old Oct 11, 2006 | 05:04 PM
teggy182's Avatar
this thread is rediculous why would u think its ok to grind down the caliper? use a spacer and why would u want 14's on a teg?
Old Oct 11, 2006 | 05:55 PM
mrdeadman's Avatar
They let me pick
Default Re: HX wheels (teggy182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy182 &raquo;</TD></TR><TR><TD CLASS="quote">this thread is rediculous why would u think its ok to grind down the caliper? use a spacer and why would u want 14's on a teg?</TD></TR></TABLE>
You are being ridiculous. Somebody asked me today "when are you gonna put 18s on" i told him im gonna put 14's on... that shut him up. But seriously smaller wheels are better for perfomance, you have less unsprung mass which helps you acclerate and decelerate faster. Big wheels are hideous.
Old Oct 11, 2006 | 07:40 PM
EGdriva's Avatar
Banned
i just saw that my right rear tire is developing a bulge so I will be getting the HX wheels. About the same price as a new set of tires. In 14's.
So, I guess I'll spend the 140 bucks on the HX wheels.
