HX?
Old May 5, 2008 | 09:21 PM
0LdsKooL's Avatar
Default HX?
I got a set of HX rims and was wondering if it will fit directly on a 92 integra? I heard it will bolt right in and others said I have to custom soething.. ay help would be great thanks and BTW I didn't have a to try it on
Old May 5, 2008 | 09:51 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: HX? (0LdsKooL)
Your gonna need spacers, the rims will grind on the caliper.
So either get spacers, or grind down your calipers.
Old May 6, 2008 | 09:27 AM
0LdsKooL's Avatar
Thanks for the info.. But one more thing one size would I need 10mm or 5mm?
Old May 6, 2008 | 01:24 PM
TunerN00b's Avatar
Default Re: (0LdsKooL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0LdsKooL &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info.. But one more thing one size would I need 10mm or 5mm?</TD></TR></TABLE>
5mm will allow those wheels to clear DC front brakes, no clue on DA brakes. However, I believe (no personal experience here) anything more than 5mm is unsafe without extended studs. Try the 5mm spacer, and if it still contacts the caliper, grind the caliper.
Old May 6, 2008 | 01:41 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (TunerN00b)
Yes 5mm is good.
i tried running a bigger size before, and it f'd up my studs and lugnuts.
Old May 7, 2008 | 09:06 AM
0LdsKooL's Avatar
So if I get the 5mm I won't need extend studs?
Old May 7, 2008 | 09:29 AM
Rainy City's Avatar
Most likely not, why don't you get it and try it out.
Old May 8, 2008 | 12:13 AM
0LdsKooL's Avatar
Does anyone have pictures of, how much I should sand down to make the HX fit my integra?
Old May 8, 2008 | 12:16 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0LdsKooL &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have pictures of, how much I should sand down to make the HX fit my integra?</TD></TR></TABLE>
There used to be a huge write up on it.. I searched and couldn't find it
Just try test fitting the wheel on there and you will see where it's hitting.. Get a dye grinder and grind them down..
Old May 8, 2008 | 12:21 AM
0LdsKooL's Avatar
I'll try it tomorrow.. I know that the back fits but I gotta try it out I'll let you guys know how it turn out
crxpwr1
Apr 16, 2007 01:33 PM
SkoundrelUSA
Apr 10, 2007 02:16 PM
crxpwr1
Mar 8, 2007 12:43 AM
99_red_si
Aug 4, 2006 06:49 PM
Kyles ej1
44
Mar 21, 2005 09:47 PM
