Humming Noise from Intake
Old Feb 3, 2003 | 04:56 AM
ph0en1x's Avatar
Default Humming Noise from Inside Intake Manifold
I have a 98 integra ls and there is a humming noise coming from inside my intake, It makes the noise with or with out the stock filter on it. I know about the whistle that the intakes make but this is a humming noise when it is at idle. Does nayone know what this could be?
[Modified by ph0en1x, 7:36 AM 2/3/2003]
Old Feb 3, 2003 | 05:12 AM
beaterman's Avatar
Default Re: Humming Noise from Intake (ph0en1x)
what type of intake do you have. certain ones humm. my friends does this and there is nothing wrong.
Old Feb 3, 2003 | 05:24 AM
ph0en1x's Avatar
Default Re: Humming Noise from Intake (beaterman)
It is the stock intake. It is coming from inside the intake manifold.
Old Feb 3, 2003 | 07:15 AM
ajchen's Avatar
ran into this problem this weekend...
check where your intake manifold connects to your block. you may have a cracked intake manifold gasket, and a leak will cause that humming sound. if you have a leak, you should have an irregular idle as well.
if your car is working fine besides the humming sound, i wouldnt worry too much about it.
Old Feb 3, 2003 | 07:50 AM
NeoGSR's Avatar
Default Re: Humming Noise from Intake (ajchen)
good advice
Old Feb 3, 2003 | 07:54 AM
ph0en1x's Avatar
Default Re: Humming Noise from Intake (NeoGSR)
Thanks ALot, I will check it out.
Old Feb 3, 2003 | 11:00 AM
ph0en1x's Avatar
Does anyone know if there is a good performance Gasket that I can get for my intake manifold?
Old Feb 3, 2003 | 11:12 AM
ajchen's Avatar
was it cracked?
i bought myself a hondata intake manifold gasket for my GSR for $62 shipped... you can find it on the Best Buys forum... a dude by the name of 2K_ITR is selling them through ks-motorsports.
Old Feb 3, 2003 | 01:37 PM
Turbo Powa's Avatar
Exactly what I was gonna say!!
Old Feb 3, 2003 | 03:48 PM
InTeGrA B18b1's Avatar
Default Re: Humming Noise from Inside Intake Manifold (ph0en1x)
i sit whistling? and when u shut ur engine off can u hear it?
Old Feb 3, 2003 | 04:44 PM
LsVtec23's Avatar
it is a lil turbo hiddin in ur intake
Old Feb 3, 2003 | 05:16 PM
B2FiNiTY's Avatar
Normal to me.
Old Feb 3, 2003 | 05:23 PM
lshobo's Avatar
Default Re: Humming Noise from Inside Intake Manifold (B2FiNiTY)
my AEM cold air hums at idle and whistles when i get on it.b
Old Feb 3, 2003 | 07:05 PM
ajchen's Avatar
Default Re: Humming Noise from Inside Intake Manifold (lshobo)
guys, he said its coming from his intake manifold... he's got a stock air box on his car.... which leads me to think its a gasket leak.
Old Nov 10, 2010 | 10:20 AM
too_alive's Avatar
Hey, everyone. I'm having the same problem, well kinda. I have a high and low in on idle. It jumps about 2 rpm. I've had five head gaskets blow. every time different place. I've had the head milld port polished everything from the block up is new, but I keep getting water in my cylinders and all the way back into my intake. I cannot figure out what the hell is going on.. PLEASE HELP!!! After I rebuild it the last two times runs great for about a week then I get the water back.. Please email me at tblankenship89@gmail.com or facebook for a quick respond. Thanks.
potatointegra01
Mar 14, 2016 12:07 AM
Jk_DC2
May 28, 2010 02:24 PM
deadmemoryy
Dec 12, 2007 08:24 PM
aznxpyroboi
Jun 1, 2007 08:21 PM
h-townteg
Jun 15, 2006 10:57 AM
