huge problem , lots at stake
Old Jun 23, 2006 | 08:33 AM
flatblackintegragsr's Avatar
Default engine knocking i think (i hope not)
I was at the track runnin pretty good times, messing with the boost, and all was well.
...except once i left for home, i heard a tiny knocking which i thought was a body part shaking or somehting...i kept driving for 2 or 3 miles. Until i realized my car knocked more and had much less power it seemed when i was trying to catch up with my friends. I turned it off and got it towed to a shop i go to.
they said they put a stethoscope up to the block, and since it was "coming from the bottom end, i should just get a new engine." I built the bottom end 20k ago, which doesnt mean much but what the guy said really confused me. I noticed a lot of oil on the valve cover, so i think maybe a plug got drowned and thus it might be running on 3 cylinders (i hope to God).......
help me out, any advice would be greatly appreciated
Modified by flatblackintegragsr at 9:43 AM 6/23/2006
Old Jun 23, 2006 | 09:52 AM
Wendys or Bust's Avatar
a drowed plug won't make your car knock. More than likely you spun a rod bearing.
Either that or a lose valve that is hitting the piston slightly. Take of the head and play with the valves, if they seem fine its probobly a bearing.
sucks
Modified by Wendys or Bust at 11:20 AM 6/23/2006
Old Jun 23, 2006 | 10:18 AM
Ilovemyemone3's Avatar
aww that sucksss
Old Jun 23, 2006 | 01:30 PM
JThrasher79's Avatar
Default Re: (Ilovemyemone3)
was there a warrenty on the block since you got it built 20k ago? that seems like low milage to be messin up..
jdmeg2808
Nov 24, 2009 10:47 AM
ch0g0nda
10
May 5, 2007 02:34 AM
ownedbyvtec
May 15, 2006 10:16 PM
blykins
15
Mar 31, 2003 06:53 AM
EGchino
Jan 20, 2003 03:55 PM
