how to remove back seats?
Old Jul 25, 2003 | 11:25 AM
kaj's Avatar
kaj
Default how to remove back seats?
i know it's basic, but i can't figure what is holding the "loops" in on the fronts of the seat (cushion).
also, i can't figure out how to take out the fold-downs...
i don't want to break anything. i removed the liner from the back of the fold downs.. but that's about as far as i've gotten.
HELP!!
i need to know in the next two hours (races tonight)
Old Jul 25, 2003 | 11:37 AM
garados's Avatar
Default Re: how to remove back seats? (kaj)
just pivot the seat cushion up, then the hoops will slide out. If the 2dr is like the 4dr, there are 4 bolts holding the seat to the mounting brackets, one bracket per side, two bolts per bracket. The brakets are on the lower corners of the seat. I think that's how it's done. HTH.
Old Jul 25, 2003 | 11:39 AM
kaj's Avatar
kaj
Default Re: how to remove back seats? (garados)
i'll go check it out. thanks! brackets on the fold down portion, i'm assuming? i'm gonna go look right now. thanks again
Old Jul 25, 2003 | 12:05 PM
kaj's Avatar
kaj
i found the plastic c-clip that i remove to slide the fold downs over and take them out. i also found out how to lift the cushion up to remove it. thanks!
Old Jul 25, 2003 | 12:44 PM
garados's Avatar
no problem ^_^
fusion645
Apr 4, 2011 01:27 AM
chunkybs
24
Apr 23, 2006 01:56 PM
confutatis
Apr 10, 2006 08:45 AM
SomeDude56
Nov 13, 2005 10:01 PM
gleinz
Sep 25, 2002 12:33 PM
