How to install one piece headlights??
Old Aug 8, 2007 | 01:57 PM
jdmjunkie8's Avatar
Default How to install one piece headlights??
I have heard everything like you have to buy a wiring harness for them and do some drilling. I wanna no what all you have to do to put them in before I buy them. Anyone wanna fill me in that would be great. Thanks
Old Aug 8, 2007 | 05:35 PM
PACT man's Avatar
Default Re: How to install one piece headlights?? (jdmjunkie8)
They bolt up the same as far as the brackets go. The headlight bulbs are a different type and will either require some cutting and wiring to wire them up or you can get the Password:JDM headlight harness. You might have to wire up the foglights also. The one pieces use a bulb size H4H which are a pain to find but there is a write-up of how to convert to use the H4 bulbs if you wanted too but then you wouldn't be able to go back to the H4H's.
Old Aug 8, 2007 | 08:00 PM
DA_PoWeR's Avatar
were are you buying your one piece head lights at? password jdm is all out of stock.
Old Aug 8, 2007 | 09:25 PM
Rajin's Avatar
Default Re: How to install one piece headlights?? (DA_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">were are you buying your one piece head lights at? password jdm is all out of stock.</TD></TR></TABLE>
HMotors has a few.
You have to cut the old headlight harness and wire the H4Hs up.
They bulbs run 45.00 to 100.00 for replacements so make sure you realize when they go out.
Old Aug 10, 2007 | 10:00 AM
SLAMMED_DB's Avatar
i heard wiring them up is pretty easy, as for myself, ive never done it but soon will. you need to take off your front bumper then unbolt the stock headlights off, then rewire, then bolt back on.
lilazn71
Oct 13, 2007 11:38 AM
the niz jiz
Jun 28, 2006 02:37 PM
SpleenBoy
Jun 7, 2006 12:07 PM
92-h23a1
May 23, 2003 08:13 AM
DIY_Racing
Jun 28, 2002 09:50 AM
