how to fix damaged thread?
Old Oct 12, 2001 | 04:35 PM
1fastGSR's Avatar
New User
Default how to fix damaged thread?
When I installed my JDM header, I overtightened one of the bolts that hold the lower support bracket for the header. The bolt kept turning without getting tighter so I removed it and noticed that I stripped the thread on the engine block where the bolts goes. How do I fix that?
Old Oct 12, 2001 | 04:44 PM
miketegra's Avatar
Default Re: how to fix damaged thread? (1fastGSR)
Just edit and save your changes
I recommend using a tap. Tap new threads, use a heli-coil or some other threaded insert, and viola, use the old bolt to secure the bracket.
Old Oct 12, 2001 | 04:56 PM
1fastGSR's Avatar
New User
Default Re: how to fix damaged thread? (miketegra)
I am a lil ignorant on this. What does a tap do exactly? Also, the space under there is pretty limited so I am not sure it will work!
Old Oct 12, 2001 | 07:26 PM
mercury's Avatar
New User
A tap looks kinda like a drill bit, but it's used to cut threads. There's actually a bit of technique you have to learn when using a tap, so you should try it out on a block of scrap metal first.
Old Oct 12, 2001 | 08:01 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: how to fix damaged thread? (mercury)
Go to a hardware store and ask for a Heli Coil kit. Bring the bolt to match up to the correct size Heli Coil. You tap out the hole and install a "thread" like deal into the hole and it'll allow you to use the same size bolt as before. It comes with everything you need in one small kit. I've used it in Aluminum and steel blocks. It works great! Good luck!
Old Oct 12, 2001 | 10:31 PM
leechungsr's Avatar
How I got it fixed......I paid someone 100 dollars to take that biotch out, and put in a new bolt.
WhiteSlips
Sep 30, 2014 05:35 PM
xanonymousx
Aug 28, 2007 08:03 PM
SkoundrelUSA
21
Aug 24, 2006 02:45 PM
garylythgoe
Aug 1, 2006 11:56 AM
albert butterbikini
Jun 30, 2001 02:54 PM
