Hit a curb- quick question
Old Aug 13, 2003 | 07:00 PM
config's Avatar
Default Hit a curb- quick question
Today i decided to take the 15 mile trip or whatever to the nearest mountain/hill area so i could have fun with fast turns etc. Anyway, there is like noone on these roads, so im taking a turn at like.. 40?, and there are 5 people just standing there on the left side of the road. So being a dumbass, i turned and looked at them for a second, and before i knew it i hit the ******* curb.
i stopped and checked it out, and i took a pretty fat chunk out of my tire, and the wheel lip is pretty fucked up too. I think my front right wheel hit the curb and went up it, and the rear right wheel just slightly hit it.
Anyway, im just wondering, besides cosmetical damage, is there anything else i could have messed up? Is there anything i could have bent or damaged? Shocks/springs etc?
What exactly should i check for? I've never hit any huge potholes and never curbed my wheels, so i'm not really sure what exactly could have been damaged.
Thanks a lot
Old Aug 13, 2003 | 07:09 PM
J337_UNIT's Avatar
Default Re: Hit a curb- quick question (config)
might just need an alignment job...you probly didnt break a suspension arm
Old Aug 13, 2003 | 07:16 PM
config's Avatar
Default Re: Hit a curb- quick question (J337_UNIT)
How can i tell? Just jack it up and look around? compare to other side?
Old Aug 13, 2003 | 11:24 PM
ill phil's Avatar
Yeah, you might be able to feel any slight damage by how the car drives- such as a wobble or something of the sort. You may want to get an alignment depending on hard you hit it and it may be wise to do that just in case.
Old Aug 14, 2003 | 12:16 AM
djay86's Avatar
Default Re: Hit a curb- quick question (ill phil)
when i hit a curb it pushed the wheel back 3 inches on my CRX
Old Aug 14, 2003 | 07:14 AM
DCStreetHtch's Avatar
Default Re: Hit a curb- quick question (djay86)
jack up your car...
in the front:
look to make sure the anchor is still bolted up straight... this the bracket up top in the very back that has two bolts going up into your engine bay, make sure the bracket isnt bent, broken, or torn. Make sure the ball joint is still in tact, while it may be torn as long as its still bolted up, not loose bent or broken, then thats cool. check your A arm, the one closest to you, see if it looks bent out of shape... basically just keep working your way through al the arms and bolts and make sure none are bent, broken or torn... do the same for the rear!
initiative is your friend...
-Bryan-
Brandon04GT
11
Apr 7, 2013 07:19 PM
happy_guy
Sep 26, 2005 03:50 PM
The Hooligan
10
Sep 3, 2004 05:18 PM
joek84
Mar 22, 2004 05:14 AM
Bantam
Mar 24, 2003 01:27 PM
