to high of compression?
Old Oct 10, 2013 | 02:59 PM
Shane4civic's Avatar
Default to high of compression?
I have a b18b1 with high rise pistons on stock rods with acl race bearings and arp head studs, we milled down the rods and everything runs great however I want more, thinking v tec head suggestions b16? b18? I was told im running to high of compression for a b16 v tec head? thoughts? my compression is 11.5
Old Oct 10, 2013 | 05:37 PM
B_Swapped93's Avatar
Default Re: to high of compression?
milled rods ? dafuq ? you mean milled head/decked block ?. gsr head or type r if you'd like a bit of porting and VJ done all ready.
Old Oct 11, 2013 | 07:12 AM
no we had to mill the rods to get they type r pistons to fit, and the r high rise pistons, the clearance level I guess is to high for a b16 head, so I have to go with a b18c head
Old Jun 17, 2014 | 10:43 AM
alos having another problem, my car now has a bog at low rpm's at random times, i have changed fuel filter, fuel pump, has after market fuel pressure regulator running 40 psi, new distributor, new battery, spark plugs and wires, help im tired of throwing money at this and nothing working, i have changed pcv all sensors on intake manifold and throttle body! any ideas ?
Old Jun 17, 2014 | 12:19 PM
jdmjunkieXL's Avatar
A gsr head will give u higher compression than a b16 or type r head. What type r pistons are in it ctr or itrs? Also u might wanna check out your tps for the bogging
Old Jun 17, 2014 | 03:03 PM
Pimptegr4's Avatar
Well I think 40 is low to start with, I ran 50 on the friends car when I worked on it. What about the injectors, the stock ones are usually maxed out fairly quick for lsv.
Old Jun 17, 2014 | 03:34 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
A GSR head would net you about .5 points more compression than a B16/ITR head. Even Jesus knows that.
Old Jun 19, 2014 | 09:25 AM
1ls/vtec's Avatar
I'm running ITR pistons in my lsv setup with the same block and a B16A2 head. Have had no clearance issues. We also had to have our shave some off on my rods or pistons too for fitment on to the stock ls rods. Can't remember, it was over 7 years ago
Old Jun 20, 2014 | 08:59 AM
Pimptegr4's Avatar
I don't think hes looking into the high comp question anymore, What is the car tune with if its even tuned.... using a stock ecu with this setup would most likely give you that kind of issue to btw.
Old Aug 27, 2014 | 12:03 PM
that i didnt know its just a random bog on the LS and i cant seem to track it down
airmaxbri
Feb 9, 2010 06:28 AM
Type R 00
Jan 26, 2007 06:42 PM
L33TsAbabyEater
Sep 11, 2006 06:53 PM
ViF CrX
Aug 29, 2006 05:48 PM
jeremy.
Jul 13, 2003 08:31 AM
