HID Question
Old Feb 24, 2004 | 08:29 PM
matt2001teg's Avatar
Default HID Question
I am not really fimilar with the hid business but I was wondering if oem hids are around 4500k? I am really looking to by a set of honda/acura hid set up, do any of you know the rating on them? And if any of you know any other oem manufactures who make hids around 4500 k please post them for me....nissan, toyota, audi, bmw.
Old Feb 24, 2004 | 08:30 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HID Question (matt2001teg)
All OEM HID is 4100-4300K. If you want to learn alot, check out http://www.hidforum.com
Old Feb 24, 2004 | 08:32 PM
NightRiderS2K's Avatar
In-N-Out Burger
All if not most new, current, and past OE equipped cars came with 4100K HIDs.
You can trust me on this one...
-NRG
EDIT: ugh Patrick beat me to it Patrick!
Old Feb 24, 2004 | 08:34 PM
typeRSXS's Avatar
just dont get any higher then 6000k and you'll be set
Old Feb 24, 2004 | 09:03 PM
jmcy's Avatar
Default Re: (shupaGSR)
which hids are on the audi's & porshe? i really like the vibrant purple!
Old Feb 24, 2004 | 09:15 PM
SHystrdyGSRtdy's Avatar
Default Re: (jmcy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmcy &raquo;</TD></TR><TR><TD CLASS="quote">which hids are on the audi's & porshe? i really like the vibrant purple!</TD></TR></TABLE>
it's not the hid bulb/ballast where i'm willing to bet you're thinking is causing it. it's the projector. you want that look? you go get yourself new projectors...bmw or audi ones and do retrofit... to find out more about that go to the top right of the screen and click search and you shall receive
Old Feb 24, 2004 | 09:59 PM
Community Builder
Default Re: (iLUVmySH)
hidforum has tons of retrofit photos. Audis use Hella projectors, as do Mercedes E55's which is what I now have in my car.
NRG - gotta be quicker on the draw, young grasshoppa j/k
Old Feb 25, 2004 | 06:21 AM
Default Re: (PatrickGSR94)
I was thinking of doing a retro or just buying the phillips 6k, where is the cheapest place to get oem hids or the phillips. Thanks for everyones help!!!
Old Feb 25, 2004 | 09:20 AM
Community Builder
Default Re: (matt2001teg)
ebay
Old Feb 25, 2004 | 09:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt2001teg &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of doing a retro or just buying the phillips 6k, where is the cheapest place to get oem hids or the phillips. Thanks for everyones help!!!</TD></TR></TABLE>
like i told everyone before... i would recommend doing the retrofit (assuming you are capable of it- my tools were very limited and i did it) over the 6k phillips anyday IMO
Old Feb 25, 2004 | 11:04 AM
superthug's Avatar
If I get say Hella Projectors, can I use aftermarket HID on them or do I have to get Hella HID or Xenon setup. Same thing with ballasts...are they interchangeable with other kits?
Old Feb 25, 2004 | 11:15 AM
Default Re: (superthug)
capsules are capsules...ballasts are ballasts for the most part...i have hella ballast w/ phillips capsules...i had mr.jung's capsules and hella ballasts, but did the retrofit and i have what i have now
Old Feb 25, 2004 | 04:52 PM
Community Builder
Well Hella and Philips are pretty much the same company, my Phillips D2S bulbs came in boxes marked Hella.
But yeah any D2S bulb will fit, but I highly suggest using Philps/Hella or Osram Sylvania.
Old Feb 26, 2004 | 08:38 PM
superthug's Avatar
and if I do a retrofit with the oem projectors, how do I make sure that the beam is right? like the placement of the projector.
Also if i get regular projectors and if i wanted to upgrade later on to bi-xenon. I would just have to change the projectors right?
Old Feb 26, 2004 | 10:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superthug &raquo;</TD></TR><TR><TD CLASS="quote">and if I do a retrofit with the oem projectors, how do I make sure that the beam is right? like the placement of the projector.
Also if i get regular projectors and if i wanted to upgrade later on to bi-xenon. I would just have to change the projectors right?</TD></TR></TABLE>
http://www.hidforum.com is a good place also... http://www.skafia.com has the write up and great pictures....
Old Feb 27, 2004 | 04:53 AM
ebelp's Avatar
The bi-xenon solenoid is built onto the projector itself, so you'd have to change the entire bi-xenon projector assembly.
Old Mar 10, 2004 | 07:10 AM
superthug's Avatar
Default Re: (ebelp)
OK I just bought myself a whole Audio Xenon setup with projectors. They're going to go in my 1-piece lights for my DA. What should I do about the reflectors in the housing? Some guy I read just cracked the reflectors and gutted it and put projectors in.
Old Mar 10, 2004 | 08:31 AM
Community Builder
Hmm I hope you can fit them in there, DA headlights seem kinda narrow (top to bottom dimension) as far as headlights go.
You should also try sanding off the flutes inside the lens so you will have a clear lens in front of the projector. Tony the Tiger on H-T and on HIDforum has done this with his Camry headlights, and some other people have done it w/ other headlights, also.
Old Mar 10, 2004 | 01:36 PM
superthug's Avatar
sick!!
http://www.hidforum.com/forum/...camry
Old Mar 10, 2004 | 01:43 PM
superthug's Avatar
upon further searching I found this to clear the flutes inside the lens. Good for anyone trying to do the same thing.
http://faq.auto.light.tripod.c...s.htm
and this thread
http://www.hidforum.com/forum/...lutes
Old Mar 17, 2004 | 04:25 PM
JUSTCRX's Avatar
any of you guys know where to buy just the bulb? one of mine went out and i know just buying one would not be the same color as the other, so i am planning to buy a pair. i have an aftermarket 9006 phillips bulb.
Steve
Old Mar 17, 2004 | 06:50 PM
VTECorona's Avatar
Default Re: (JUSTCRX)
http://www.hidtech.com also has OEM HID projectors and HID kits for sale. They even do retrofits on your oem housings. It is a fairly easy DIY project, definitely not worth paying what they want for it.
hidtech has Hella bi-xenon projector + HID packages for 449.99. That is a bit pricey compared to ebay prices but I personally would prefer new parts over used parts.
Included is:
2 Hella ECE spec D2S projector. (Audi A6 OEM Components)
2 Hella generation III ballasts.
2 Philips 85122 D2S HID bulbs (4300K).
Old Mar 17, 2004 | 07:28 PM
Community Builder
Default Re: (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hidtech.com also has OEM HID projectors and HID kits for sale. They even do retrofits on your oem housings. It is a fairly easy DIY project, definitely not worth paying what they want for it.
Included is:
Well the projectors are obviously going to be used, are you sure the ballasts are new in those packages? If so, $449 is a pretty good price.
Old Mar 17, 2004 | 07:40 PM
..::91TEG-G2::..'s Avatar
anyone have any pics of the DA with that projection setup..
Old Mar 17, 2004 | 10:11 PM
superthug's Avatar
Default Re: (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">anyone have any pics of the DA with that projection setup..</TD></TR></TABLE>
I'm working on it, I got bi-xenon projectors from audi and the whole system. I'm going to try putting it in my 1-piece lights. Also clear up the flutes on the lens so the cut-off could be sharper.
