HID front conversion installation
Old Mar 19, 2006 | 10:04 PM
sleezyted's Avatar
Default HID front conversion installation
I am having a little trouble with the HID installation for the jdm front conversion. i have a 95 integra and i know it wont fit because of the abs. is there another way to cut the wire and extend it? if there is can you guys help me out with pics. I tried looking thru threads for about 1 hour now. I am a noob afterall. If someone can help me that would be great also if there is a place in socal (if i cant do it myself) taht i can go to in order to install it
Old Mar 19, 2006 | 10:56 PM
vinai's Avatar
Default Re: HID front conversion installation (sleezyted)
I've been told that you can bend the ABS. Yes, so definetly use the search feature.
Old Mar 19, 2006 | 11:50 PM
sleezyted's Avatar
Default Re: HID front conversion installation (vinai)
we have to bend it? is it possible to bend it? i will try that and i will use the search feature. thanks
Old Mar 20, 2006 | 12:02 AM
Circuit Star-29's Avatar
STOP!!! Do not bend anything...unless you intend to remove the abs. Just get an HID kit w/ D2S HID bulbs w/ the connectors...this is the easiest way to make this happend.
Old Mar 20, 2006 | 04:17 AM
eluam's Avatar
Default Re: HID front conversion installation (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">STOP!!! Do not bend anything...unless you intend to remove the abs. Just get an HID kit w/ D2S HID bulbs w/ the connectors...this is the easiest way to make this happend.</TD></TR></TABLE>OEM &gt; Kit anyday. Its worth the work to make the OEM work.
Old Mar 20, 2006 | 09:05 AM
dcRay's Avatar
Default Re: HID front conversion installation (geeZus)
The headlights are already hid, I think he ask him to use a smaller ballast from the kit.
Old Mar 20, 2006 | 12:17 PM
Default Re: HID front conversion installation (dcRay)
The OEM HIDs will not fit a 94-97 integra w/ abs...if you use an HID kit w/ d2s bulbs 4300k the color will be similar and the cutoff will be the exact same since its not the bulb, its the projector doing the work..
This is my opinion as to make something that won't work, work.
Old Mar 20, 2006 | 10:10 PM
sleezyted's Avatar
it wont fit? well heres what i did.... i extended the wires and put the balist or watever u call it under the headlight!! lol i did my own diy i guess. ill post up some pics. but its good. guess this is a way people can "diy" for the jdm hid headlights on the 94-97 and yeah i didn't bend anything
Old Mar 20, 2006 | 10:13 PM
Nice...I'm interested in how you accomplished this because Im in the same boat. HID w/ a 94 Integra.
Canceltune
Apr 13, 2008 09:23 PM
InTeGrA GsR 321
Feb 12, 2007 11:22 PM
Joe Psycco
Jul 20, 2004 03:35 AM
DC2NV
Feb 17, 2003 10:29 AM
jin
Oct 12, 2002 10:05 AM
