Help!!! wrong light lol
i posted about my "check engine" not goin off cause there are no codes but it wasnt check engine light it is the damb maintenance required light any ideas on how to turn it off i found the problem it was cause i was low on oil i think the shop that did a quick change forgot a qrt. of oil.
Help!!!!
Help!!!!
if your sitting on the drivers side reach under your dash on the right side there is a small square button you can feel.....press it for a few seconds and the maint light turns off
we were all there man.. lol.. if it dont go away while just holding it, then u gotta have the key in the off position, press and hold the button while u turn the key to the run position.. dont let go of it until the maintenance light turns off.. then it should be reset..
Help!!!!
Help!!!!
