HELP!! wont start!!
Old Aug 29, 2011 | 09:23 PM
Zukka's Avatar
Default HELP!! wont start!!
Ok i have a 97 Turbo GS-R i recently converted to obd1 harness for my 93 civic. Well before i swapped the harness the car would sit and crank every once in awhile it would studder like it wanted to start, but wouldn't. If it did start it would maybe get two crank revolutions before dying, even with someone personally turing the throttle body. Well i swapped harness thinking obd2 pin out was different so i swapped in hope she would start. Well now im back to the same EXACT spot. I've checked everything fuses, relays, fuel pump(which you do hear it prime), I even took my fuel rail off with my injectors still on to make sure the injectors where spraying( which they are). Ive got a brand new distributor with the obd2 to obd1 jumper harness and same for the altanator. Ive got spark all the way to the new irdium spark plugs. I hooked my computer up to hondata its showing no codes accept Barometirc something, but I bypassed it. I dont understand whats wrong. Can anyone help????? Also gas is fairly new i got shell 93.
Old Aug 29, 2011 | 09:29 PM
Fliptard's Avatar
Default Re: HELP!! wont start!!
Is it an OBD1 or 2 computer?
And the Baro pressure is the MAP sensor and a sensor inside the ECU.
I THINK, not 100% sure. the baro has a kind of base map inside the ECU to tell the car how much fuel/air it needs up untill so many RPMS, then it reads it from the crank, map sensor.
Old Aug 30, 2011 | 04:28 AM
Zukka's Avatar
OBD1 computer, do you know which map sensor? its thrown this code since i have had hondata ive just gone in a had it bypass it.
Old Aug 30, 2011 | 05:48 PM
Fliptard's Avatar
Well, you need a Map sensor.
From what I know, alot of people use a GM 3 bar map sensor i think it is. I'm not for sure tho. Just google "Map Sensor for turbo GSR" or "What Map sensor to use with a turbo GSR" use key words and just search and read till you find something.
Old Aug 30, 2011 | 05:52 PM
Zukka's Avatar
but if i bypass it through hondata its should start right? cause i mean if it was something as important as you say they wouldnt let you right? but if you go to the sensor option on the drop down in perimeters its like the third or fourth one that you can say use or not.
Old Aug 30, 2011 | 05:53 PM
Zukka's Avatar
could pistons get so saturated with gas they dont fire? Basically flooding it? If so how can you get ride of that gas?
Old Aug 30, 2011 | 06:21 PM
Fliptard's Avatar
Your map sensor reads how much pressure (air) is being sucked, or pushed into the intake so it knows the correct fuel/air ratio it need to put out to make the car run right. If it can't read it... how would it know the correct mixture to run?
Fliptard's Avatar
https://honda-tech.com/forums/forced-induction-16/gm-map-sensor-gsr-turbo-setup-1680211/
Old Aug 30, 2011 | 07:25 PM
Zukka's Avatar
alright ill check it out thanks alot
dajuice_8
Jun 17, 2014 05:55 PM
civic95hbvtec
Apr 14, 2009 05:19 AM
Kusai.Nihonjin.Desu
21
Apr 16, 2005 08:08 PM
xerox445
16
Jan 28, 2005 09:10 PM
BseriesN1
Jun 13, 2004 07:24 PM
