help with vtec wires
Old Oct 24, 2005 | 01:19 PM
p-nutz's Avatar
Default help with vtec wires
I put a 1.6 vtec in my 91 integra. Runs good but need to wire vtec oil, solenoid, knock, and 2nd o2. I've gone to many sites and can't get the same results on where they go. Could someone please help me get some good running vtec power in my ride.
Old Oct 24, 2005 | 05:58 PM
hawjboi's Avatar
Default Re: help with vtec wires (p-nutz)
have you searched yet...if you have you didnt look hard enough...but here is a link to a FAQ page of ecu questions...
here you go...thank me later...
https://honda-tech.com/zerothread?id=1171263
(you might have to run additional wires (91 integra))
Old Oct 25, 2005 | 02:55 PM
p-nutz's Avatar
Default Re: help with vtec wires (hawjboi)
Thanks for all of your wrong help. Its people like you that think they know it all and don't take the time get the right facts. Believe me I've been searching and this is the same reason my car still isn't wired right. If you're going to help someone, I suggest you know what the hell you're talking about.
Old Oct 25, 2005 | 04:57 PM
hawjboi's Avatar
if you would read the thread that i posted you might gain some knowledge and figure out where everything goes...asumming that you have an obd0-obd1 harness all you need to do is look at the thread i pasted there and look at the ecu pinout and find out where which wire is where and wire it up to your vtec pressure swith, and oil pressure swith as well as the knock...i dont see why you have to wire up a 2nd o2 sensor its not needed if your going to run obd1 and if your ecu your using doesnt support knock then thats not needed at all either...vtec power for your ride is getting closer
h22lude317
Jan 10, 2009 01:29 AM
jdmdseries
Nov 17, 2007 09:18 PM
Crimson_Tide
Jul 29, 2005 03:18 PM
fastb16a2
Apr 23, 2005 08:35 PM
