help with teg ls
Old Jun 28, 2008 | 11:01 PM
envious's Avatar
Default help with teg ls
sup guys need help with my integra..well my battery then my alarm went off i replace my battery then my blinker and interior lights keep blinking off n on and now it wont start help asap thanks
Old Jun 29, 2008 | 09:54 AM
vtecb18c's Avatar
Default Re: help with teg ls (envious)
check the ground on the battery....or your alarm is screwed up
Old Jun 29, 2008 | 11:03 AM
salomon16's Avatar
you need to disarm your alarm. The car isn't starting because alarms have a starter kill that won't let the car crank until you disarm the security system. If your remote isn't working put the alarm in "valet" mode so you can start it and go buy a new battery/remote. If you have the manual for the alarm it will tell you how to do this. If you dont have the manual you'll have to take out your underdash and get a brand/model and look it up on the net. good luck
Old Jun 29, 2008 | 11:14 AM
RockyMtnTEG's Avatar
this same thing kinda happend to me, check the ground like was mentioned before, but also check the ignition wires under the sterring wheel and just check nothing is unconnected or odd looking...you could also check the fuses..good luck
drlovesaa1
10
Dec 22, 2007 07:55 PM
Importn2oRacer
Audio / Security / Video
Jun 6, 2007 03:22 PM
Airbag Club
21
Feb 2, 2004 02:05 PM
Orig
May 20, 2003 11:52 PM
