help with squeaks!
Old Mar 12, 2003 | 01:19 PM
speedevo's Avatar
Default help with squeaks!
anyways there is a squeak that started to develop after doing my suspension comptech springs and itr sway with bsq kit, now it sounds almost like if the surframe had ripped but it didn't maybe it's flexing?
so i got a spoon tie bar and the first time i installed it i put on the of the brackets lower than the other to the bar wasn't parallel to the sway bar and i didn't tighten the tie bar nuts too tight, so the sound was gone but today i went back to put the bracket piece back on properly and tighten the bolts back tight the sound has come back now, so what should i do, loosen the hinge bolts on the tie bar?
Old Mar 12, 2003 | 02:17 PM
mr.beeks's Avatar
Default Re: help with squeaks! (speedevo)
did you tighten to
torque spec?
and of course it will need a second adjustment after a couple of
miles of use..
Old Mar 12, 2003 | 03:11 PM
speedevo's Avatar
Default Re: help with squeaks! (FRANCISCO FLORES)
i'm not sure what should the tie bar be torqued to?
TheIntegraGuy
Suspension & Brakes
Apr 7, 2007 06:11 PM
JFG Kevin
Mar 23, 2004 04:33 AM
AzntstyleZ
Jan 26, 2004 12:05 PM
Teknic73
Aug 27, 2003 08:16 AM
Racer X
Jan 16, 2003 10:56 PM
