help plz
Old May 13, 2003 | 11:58 PM
DA_Fiend's Avatar
Default help plz
Well, i got in an accident recently, and banged my front end up pretty bad . the car requires a new radiator. well i was able to drive the car home, but had to put water in the radiator several times on the way, and always pulled over and shut off the engine before it got a chance to over heat. The car drove fine . now, ive had the car in my driveway, with the engine partially exposed to the elements (due to the hood being messed up). so i went to drive it around the block to let it go thru the gears and such, and it seemed the car had lost alot of pickup, generally didn't shift too well (did shift though). so my question is, what could have happened from the time i parked it, and the time i drove it that would make it drive like this?(i think it rained once while it has been sitting)
Old May 14, 2003 | 12:19 AM
DA_Fiend's Avatar
Default Re: help plz (DA_Fiend)
bump
Old May 14, 2003 | 01:22 AM
DA_Fiend's Avatar
anyone?
Old May 14, 2003 | 01:34 AM
NightRiderS2K's Avatar
In-N-Out Burger
Make sure that coolant did not leak into your motor. If you see any white smoke...its definitely coolant inside your engine... but please describe more in great detail the damage that occured to your car...
NRG
Old May 14, 2003 | 01:41 AM
DA_Fiend's Avatar
Default Re: (NightRider-gsR)
ok..right part of front-end (where headlight is located) smashed into immobile SUV @ 50 mph. it seems the radiator support is bent in, towards the engine. it is pushed up against the battery. the car starts the same, and idles the same as before the accident (perfect); and there is no white smoke
Modified by DA_Fiend at 7:11 PM 5/21/2003
Old May 14, 2003 | 08:24 PM
DA_Fiend's Avatar
Default Re: (DA_Fiend)
some1 please give me an idea what the problem could be!
Old May 14, 2003 | 08:29 PM
WiggiE's Avatar
New User
Check your oil level and your tranny fluid level.
Old May 14, 2003 | 09:46 PM
integraL's Avatar
was it your fault? if it wasn't, im sure your insurance has you covered.
Old May 14, 2003 | 10:10 PM
DA_Fiend's Avatar
Default Re: (2001gsRguy)
my fault .. foolish driving
Old May 21, 2003 | 02:45 PM
DA_Fiend's Avatar
Default Re: (WiggiE)
Checked my tranny fluid and motor oil..both are good. any other possibilites? like maybe water got in the distributer from rain (due to the hood not closing correctly)? or am i just being delusional? HELP!!!
Old May 21, 2003 | 03:12 PM
DA_Fiend's Avatar
Default to the top
TTT bump
Old May 21, 2003 | 03:46 PM
DA_Fiend's Avatar
apparently..no one knows or cares whats wrong or could be wrong with the car..Ohh-KAY MANG!!
Old May 21, 2003 | 03:56 PM
WiggiE's Avatar
New User
It sounds like you may have gotten water in your ignition system somewhere.
Also, pull your plugs and see if they have oil or coolant on them, or they look odd.
vgarcia25
Honda Civic (2001 - 2005)
14
Jun 10, 2011 01:20 PM
jkalex05
Aug 12, 2009 03:03 PM
ziptie
Jul 23, 2007 07:47 PM
EF4lyfe
Jun 29, 2004 02:16 PM
92GSR
Jul 29, 2002 08:16 AM
