HELP PLEASE!!!! Running light problem
Old Nov 17, 2010 | 09:08 PM
808_db7's Avatar
Default HELP PLEASE!!!! Running light problem
I just installed a set of ebay oem replica foglights. I did modify the harness the shipped me cause a harness was missing. I removed the switch and relay they provided and then wired the foglight togethe and then ran the power to the oem connector in the engine bay and then ran a inline fuse holder from the oem foglight connector to the fuse box under the steering wheel to the terminal listed for running lights.
But when i went to turn them the turned on for a few seconds then went out.
The fuse box under the dash where you hook up to the flashing light terminal no longer reads 12 volts when i turn the running light switch on.
The fuses for the running light and running light relay are NOT blown. Also nothing works when i flick the running light switch on; gauge backlight, gear selector backlight, ringing bell when door is open, front running bumper lights, rear running taillight
If anyone has had this problem or knows a possible solution please help
thanks!!!
Old Nov 18, 2010 | 05:31 AM
fcm's Avatar
fcm
Old Fart
Default Re: HELP PLEASE!!!! Running light problem
MM&Y of car would help. 94
JDM EK_97
Apr 19, 2012 07:36 PM
flipstylez86
Jun 24, 2010 06:19 PM
Vsm Ej6
Mar 24, 2010 03:21 PM
dariusz
Apr 30, 2006 04:51 PM
dcRay
Feb 23, 2005 04:40 PM
