help please: cold starting issues
I have a 91 integra ls that is giving me problems starting when its cold. i replaced the fuel pump but it still does not start. it will start with starter fluid and once it gets started and warms up it'll be fine. thanks any help is appreciated
check spark cold. then fuel. although the fact that it starts with starter fluid does lean towards a fuel related issue. maybe not priming. crack the fuel line, and see if it primes
and you're hearing the main relay click 3 times?
Joebroni
Sep 26, 2005 10:43 PM
DOHC_C-REX
Sep 7, 2004 09:55 PM
