Help please, CEL!!!
Old May 12, 2003 | 11:59 PM
.Chris.'s Avatar
Default Help please, CEL!!!
Hey guys, got a couple questions.
Tonight I was driving home from a movie with my friend in the car. We thought we'd have some fun and I wound out some gears, to the top of 4th. I went around a long corner at high speed. My engine threw a CEL at me. I think it might have starved for oil for a moment.
I pulled over and checked the oil. It was low, so I topped it up. The car still had a CEL. I drove the car home without going over 3500rpm. All operations were normal. I can't think what it might be. How do I check my cel codes and how do I find out what the numbers correspond to? I have owned the car for 70000KM with no CEL ever showing up. I drive the car hard but take good care of it (3000mile oil changes.) The car has 130 000km on it (roughly 85k miles.)
Any help is apreciated.
Do you think I should reset the ECU to see if it is still there? I think it might have been caused by oil starvation on that corner. The car was really low (I haven't been checking) when I checked it.
Old May 13, 2003 | 12:12 AM
WhitEdRift's Avatar
Default Re: Help please, CEL!!! (Black204GSR)
There was another post about this a while back. I am pretty sure a lot of people suggested resetting the ECU. For the life of me I can't remember what the other solutions were. I would wait for a few more people to speak up though.
Do a search. There are several posts related to the CEL and some solutions.
Old May 13, 2003 | 12:15 AM
B2FiNiTY's Avatar
http://www.c-speedracing.com
Old May 13, 2003 | 12:23 AM
.Chris.'s Avatar
Default Re: Help please, CEL!!! (B2FiNiTY)
Thanks for your responses guys.
I ran a search and it only had a few. Maybey I should re run that search with some different parameters.
Old May 13, 2003 | 09:35 AM
.Chris.'s Avatar
No code showing. I will reset the ECU and post results.
For those of you who may encounter this thread under a search, go to http://www.c-speedracing.com . You will find all of the necessary information on the CEL and codes. Trouble shooting these codes is another matter entirely, but at least you have a direction with the code.
Old May 13, 2003 | 12:33 PM
.Chris.'s Avatar
UPDATE: it appears I was not checking the cel codes properly (didn't have the circuit competed).
My car is showing CEL code number 22.
from c-speed:
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
* invalid code for non-VTEC engine
Anyone know how to Trouble shoot this? Is it safe to drive the car normally?
Old May 13, 2003 | 01:15 PM
WhitEdRift's Avatar
Sounds like an oil line may have come look and you are losing pressure. Check under you car for any leaks after you drive and see if you can find it. I can't imagine you would have an electrical control problem unless it was defective from the start. Try looking for a loose hose though.
Old May 13, 2003 | 01:31 PM
.Chris.'s Avatar
Default Re: Help please, CEL!!! (WhitEdRift)
There is no Oil leaking anywhere. I think that the pressure switch may be broken or something. I called my dealer and they said it was fine to drive the car. I just wont rag on it.
rjmq06
Oct 10, 2010 09:25 PM
98GSRrdr
Feb 20, 2007 12:52 PM
asiansgoweeee
May 25, 2005 10:23 PM
Poopie
Oct 10, 2004 12:32 PM
.nate
May 29, 2002 04:12 PM
