help please:(
Old Jan 13, 2009 | 11:52 AM
chatman_55's Avatar
Default help please:(
so i got up this morning went to start my car and it just cranks but will not start. then my alarm won't arm, it will lock the doors but on the pager it is showing z's over the car. the panic button won't even set it off. it is an auto page alarm system in an 01' integra. what could be going on? it has a fuel cut off switch hooked up to it.
Old Jan 13, 2009 | 12:06 PM
vietnamezerice's Avatar
Default Re: help please:(
find a way to disable the alarm... make sure you have fuel going to your motor and that the alarm isn't cutting the fuel to your motor.. i would start from there
Old Jan 13, 2009 | 12:08 PM
chatman_55's Avatar
how do i check if fuel is getting the the motor?(i don't know anything)
Old Jan 13, 2009 | 03:31 PM
unrivaled's Avatar
before you go and start to undo fuel lines just turn the key and listen towards the rear of your car for a whining/humming noise that will tell you if your fuel pump is getting cut off.
Old Jan 13, 2009 | 03:56 PM
or if you want tp spend money you can install a fuel pressure guage and moniter it that way
laoboisosilly
Audio / Security / Video
Feb 17, 2009 05:23 PM
chatman_55
Jan 13, 2009 03:19 PM
cxSHOE
Aug 20, 2005 12:46 PM
vietjdmboi
Mar 3, 2005 02:33 AM
GsrSdn
Aug 24, 2002 02:15 AM
