help oil please
Old Jan 2, 2009 | 12:46 PM
jonhstarkironman's Avatar
Default help oil please
i have had a family member change my oil back when they came to visit
the problem is
-i dont remember which brand and grade he used or if it was synthetic or non synthetic
-i'm running low, almost to the lowest dot about | | till the lowest dot
- is it good to throw in a quart of so____ and so________ before my next change?
help please
car is a obd1 gsr
Old Jan 3, 2009 | 07:27 AM
LSracing94's Avatar
Default Re: help oil please
yes its ok to add oil between changes, i use 10w30 oil, add syntech blend, it wont hurt it
Old Jan 3, 2009 | 11:33 AM
ivan93egreppin210's Avatar
do another oil change. either use all synthetic or all non synthetic. dont mix the two. im not sure if you will damage your motor to mix them but why chance it.
Old Jan 3, 2009 | 11:51 AM
racebum's Avatar
i would do one of two things. either ask the family member what they put in it or drain it and install what you normally run. and yes, it is quite normal for a gsr to use oil. how the engine is driven has a major impact. if you rarely shift above 5k a tight gsr can go the entire 3k without using a quart. if you hit 8k every time you have the chance it will be quite a good deal more.
Old Jan 3, 2009 | 09:56 PM
i just ended adding half a quart of mobil 1 synthetic 5w-30
so w/e just temporary until i do a full tune up
^yea i run the car hard sometimes
what is a good daily oil that includes semi beating (rarely, say once a week of running it)?
5w30?
1030
5w40?
10w40?
i dont know, a guy told me to run 10w40 because i have a vtec engine
should i just run royal purples? and what grade
royal purple say increase power and MPG seems tempting
Old Jan 5, 2009 | 08:49 PM
bump for recommendation and advice please
Old Jan 5, 2009 | 09:03 PM
g3Gsr443's Avatar
Purple
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
atmosphere
Sep 24, 2005 06:13 PM
B18cteg
Sep 8, 2003 10:10 PM
RacerXintegra2k
Sep 12, 2002 11:34 PM
Mike D
Jun 23, 2001 07:26 PM
