Help...No Vtec (searched)
Old Dec 21, 2004 | 08:44 PM
DavidT or VajT's Avatar
Default Help...No Vtec (searched)
I searched and looked throughout all 32 pages but haven't found any resolution. I just finished swapping in a 1st gen B16a into a 1990 Integra, and Vtec won't engage. I've checked everything. I checked all my wirings by disconnecting each Vtec pin from the ECU, and the check engine light comes on so everything works. Also ohm tested everything and everything's within specs. Replaced the Vtec solenoid, bypassed the Vtec oil pressure switch, nothing is working. The only thing I think it may be now is the ECU...but I don't know anyone local with a PR3 ECU for any testing. What do you guys think? Help me out!
Old Dec 21, 2004 | 08:51 PM
SiR Inspired ED7's Avatar
Default Re: Help...No Vtec (DavidT)
Tune up? (Oil change, etc...)
i hope these can help you
https://honda-tech.com/zerothread?id=164863
Old Dec 21, 2004 | 09:05 PM
Default Re: Help...No Vtec (92 DA B16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 DA B16a &raquo;</TD></TR><TR><TD CLASS="quote">Tune up? (Oil change, etc...)
https://honda-tech.com/zerothread?id=164863</TD></TR></TABLE>
Thanks for the thread bro, I've already checked everything that was listed. It's a JDM motor, so it's still faily new with low miles. When I put it in I basically did a full tune-up, new oil/oil filter, radiator fluid, etc. There's plenty of oil, so it's got nothing to do with oil problems. I'm thinking it's the ECU, but we'll see.
Old Dec 21, 2004 | 09:31 PM
Good Luck
Old Dec 21, 2004 | 10:10 PM
IVI's Avatar
IVI
if you give the vtec solenoid power does it click?
Old Dec 21, 2004 | 10:33 PM
Default Re: Help...No Vtec (IVI)
Yes it does click. It's brand new, replaced the old one so the Vtec solenoid works.
Old Dec 21, 2004 | 10:43 PM
MassScene's Avatar
does your speedometer work? is your speedo sensor is bad vtec wont work. your MPH is one of the things needed to activate vtec.
IVI's Avatar
IVI
what ecu are you running right now ?
Old Dec 22, 2004 | 07:15 AM
HONDA_TYPE_R's Avatar
Default Re: Help...No Vtec (MassScene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote">does your speedometer work? is your speedo sensor is bad vtec wont work. your MPH is one of the things needed to activate vtec.</TD></TR></TABLE>
Check this!!! It can cause a lot of problems.
Old Dec 22, 2004 | 07:30 AM
sleevedgsr's Avatar
Do you have your stock speedometer and your stock ecu?
S_StarGsr
Apr 29, 2017 08:24 AM
D-Atk
Mar 9, 2008 08:15 PM
racereaper7
Sep 16, 2007 05:32 PM
superchargedex
Apr 14, 2005 12:14 PM
Ch3mik
20
Mar 30, 2005 11:56 PM
