help me with my reverse light solution...
Old Jun 30, 2002 | 08:29 PM
LS-T's Avatar
New User
Default help me with my reverse light solution...
help..my reverse light is out.
its been out ever since swapping auto to manual tranny.
Anyone know where or what the problem is.
I'm taking my car this week to a mechanic for VA state inspection.
his must be in working order before passing the inspection...sigh
If anyone can tell me whats wrong so that I can mention it when i'm at the shop.
Also If anyone could tell me where i could go to fix it. Dealer? mechanic shop? performance shop?
thanks
Old Jun 30, 2002 | 08:33 PM
sutrusu's Avatar
Default Re: help me with my reverse light solution... (Armani692)
tape 2 flashlights to the car and turn them on when the guy shifts into reverse.
Old Jul 1, 2002 | 06:22 AM
LS-T's Avatar
New User
anyone ?
Old Jul 1, 2002 | 06:51 AM
shamoo's Avatar
Will you make something up for me please?
Well, I assume you tried the easy solution of checking your bulbs, right?
Anyway, look at your tranny. Do you know where the little reverse light "actuator" button type deal is? There should be a small wire harness coming out of it. It's capped on the tranny side. Do you even have that connected? Check that out.
Old Jul 1, 2002 | 06:54 AM
IC x Prince's Avatar
New User
Default Re: help me with my reverse light solution... (shamoo)
Well mine were out as well...you might wanna check the switch...I can't remember off the top of my head the procedure....but there is a switch on the tranny case. The Problem with mine was my tranny fluid was really old and dirty. Replace it all with OEM MTF...that fixed mine... goodluck.
Dalang
Sep 25, 2008 07:21 AM
HondaH22A
Honda Civic (2001 - 2005)
Jul 2, 2008 06:22 AM
hydeehydee
Sep 5, 2005 09:23 AM
jdmsteve2004
Jun 24, 2004 07:08 AM
LSintegra
Apr 9, 2003 07:01 AM
