help me identify this dizzy.
Old May 14, 2009 | 11:19 PM
ivan93egreppin210's Avatar
Default help me identify this dizzy.
not sure what obd it is or what motor it came off of. it could be from a sohc for all i know. thanks
Old May 15, 2009 | 07:26 AM
mouab18c1's Avatar
Default Re: help me identify this dizzy.
its either obd0 or obd1
Old May 15, 2009 | 09:31 AM
mpls's Avatar
obd1 b16
Old May 15, 2009 | 10:35 AM
dragon007's Avatar
on the side, it should have a stamp saying TDXX.
check it out
Old May 15, 2009 | 01:59 PM
94EG8's Avatar
Seagull Management
check it out
Exactly. I can tell you for sure its OBD1, looks to be a B-series Vtec distributor.
Old May 15, 2009 | 04:00 PM
so most agree its a b series vtec dizzy? possibly obd1? are the legs of an ls different
Old May 15, 2009 | 04:39 PM
VPUPPY's Avatar
check it out
Yes, if you google that TD-##U, you should be able to see what motor it belongs to.
Old May 15, 2009 | 05:26 PM
94EG8's Avatar
Seagull Management
[quote=ivan93egreppin210;38551173]possibly obd1?/quote]
Definately OBD1.
OBD0 -> 2 milky white plugs
OBD1 -> 2 grey plugs
OBD2 -> Single grey plug
Yes.
Old May 15, 2009 | 05:37 PM
jdm_bones's Avatar
People have told you to look for the stamp, what does it state/read?
TD-84U USDM ITR and JDM ITR/CTR OBD2
TC-08A USDM ITR and JDM ITR/CTR OBD2
TD-84U USDM GSR, and JDM GSR OBD2
30105-P75-A01 LS, GS, RS OBD2
TD-68U USDM GSR, and JDM GSR OBD1
TD-44U USDM Del Sol VTEC Si B16A3, and JDM Civic Sir OBD1
TD55 USDM LS, RS, GS JDM Esi and other like models OBD1
TD-22U JDM B16A XSI, and SiR OBD0
TD-23U/ or TD-24U USDM LS, RS, GS, and JDM like models. OBD0
I would say that it is more then likely a TD-68U as it look to be OBD1 B-Series VTEC dizzy, and GSR's are more common to find over Del Sol B16A3's.
Old May 15, 2009 | 09:26 PM
you guys are great. its a td-44. i saw it on craigslist that had it going for 30$. i went and picked it up anyway. the difference in the legs are obvious once you look at them from an LS. the LS is more like this "Y". the vtec ones have the bottom front leg like this "y" if not that leg would hit the vtec housing. now i understand why you CAN use an LS but you'll have to remove a leg.
HondaRexBoi
Apr 20, 2021 11:52 PM
AfTeRhOuRs209
Aug 23, 2011 11:14 AM
superls92
Sep 3, 2003 08:40 PM
BikeSpike
Apr 10, 2003 10:34 AM
