help me diagnose a possible problem
Old Jan 28, 2004 | 05:15 AM
b18c1995's Avatar
Default help me diagnose a possible problem
i was recently cleaning out my engine bay, and a noticed a little oil on my block. It looks like it was coming from where the head meets the block. I immediately thought headgasket, but with headgaskets you usually get overheating, and my car is not. My gsr only has 72k miles on it, and its only been beat on a few times. Any other things it could be?
Old Jan 28, 2004 | 06:01 AM
florduhdude's Avatar
Default Re: help me diagnose a possible problem (b18c1995)
Where is it leaking exactly? front of block, back? need more description dude
Old Jan 28, 2004 | 07:05 AM
au-gsr's Avatar
SOUNDS TO me like the ol cam seal leak. if it is coming from the passenger side of the engine follow the oil up the head and see if it is oozing out of the lil rubber seal on the Upper head before the distributor. my car had a nasty oil leak and i could have sworn it was a headgasket, but after i cleaned the area and found out where it was coming from i was glad to find out that it was just a simple fix.
Old Jan 28, 2004 | 12:15 PM
b18c1995's Avatar
that looks about right, on the passenger side of the engine. Can a cam seal be replaced by me fairly easily?
Old Jan 28, 2004 | 01:13 PM
sleeperek's Avatar
Default Re: (b18c1995)
definitely cam seal next to the vtec soleniod...thats a defect from acura...Hope that'll fix ur problems...
Old Jan 28, 2004 | 01:19 PM
b18c1995's Avatar
then i should go with aftermarket cam seals since acura obviously sucks at making cam seals. which brand should i go with?
Old Jan 28, 2004 | 02:11 PM
au-gsr's Avatar
DON'T WASTE YOUR LOOT ON THE aftermarket. honda re-designed teh cam seal to have more resistance to heat and seal better. even the aftermarket ones will have to be puled and the o rings replaced. Nothing last forever. and if i were to make the decision between a 10 oem part vs a 40 dollar aftermarket part. you could bet the farm i would go with oem. no reason not to(in most cases this is true)
Old Jan 28, 2004 | 03:31 PM
Default Re:
Also don't forget to check the distributor o-ring. They tend to harden and leak, in the same area. I have heard that the 94- integra cam plug uses o-rings while the 90-93 is just one piece.
Old Jan 28, 2004 | 03:48 PM
631 Teggy's Avatar
Default Re: Re: (florduhdude)
yeah your cam seal will use one o-ring per seal... get a Golden Eagle one (cheap), that comes with 3 orings... Aint ganna get no leaks with these babies!
Old Jan 29, 2004 | 06:46 AM
au-gsr's Avatar
Default Re: Re: (631 Teggy)
so my question is once it does leak, because it will as all rubber will break down over time. where do you find the o rings, how much do they cost and are tehya common size to find in case the manufacturer is out.?
Old Jan 29, 2004 | 06:50 AM
631 Teggy's Avatar
Default Re: Re: (au-gsr)
if properly lubricated with install, there is a very small chance that the o-rings will begin to leak before the engine dies...
If it does happen - I'm sure GE will supply you with orings - otherwise ou can find them anywhere...
Old Jan 29, 2004 | 06:53 AM
sleeperek's Avatar
Forget the the new seals.....Just take out the old one and HONDA BOND that sucker....Honda BOND will seal anything....The best sealant I've ever use.....Don't waste money on any new seals...just get HONDA BOND ...trust you will not be dissappointed....Go tto any Honda/Acura dealer...
Old Jan 29, 2004 | 07:22 AM
krn.racer's Avatar
the engine head could jus be dirty......
Old Jan 29, 2004 | 07:52 AM
91integraLSVTEC's Avatar
Default Re: help me diagnose a possible problem (krn.racer)
i have the same problem with my ls/vtec.. the oil is coming from the vtec soilinod valve.. all i have to do is replace the gasket just finding a gasket that fits 1st gen b16a
scspeed
Mar 28, 2010 06:50 AM
mouab18c1
Jan 26, 2010 12:43 PM
CiSmoEk4
10
Dec 25, 2005 05:56 PM
confewcious
Jul 27, 2005 08:55 PM
colombian linx
Dec 21, 2004 09:42 AM
