help me
Old Mar 26, 2008 | 10:03 PM
monkey_boi's Avatar
Default help me
ok so you guys i just bought a 90 da ls
and the car is clean title from what i know never been in a accident
but there is something off about the car
when i drive the car humms .....
i have had someone past by in the car and you can not hear it from the outside but you can hear it from the inside in the rear,
the funny thing is the faster you go the louder it gets.
so i am thinking that maybe the car is rubbing on something but what could it be does anyone know ??????
Old Mar 26, 2008 | 10:07 PM
Ruthlessef9's Avatar
Default Re: help me (monkey_boi)
i wish i can help but bump too find the problem
Old Mar 26, 2008 | 10:13 PM
Sleepy0132's Avatar
Banned
check your tires, are they rubbing or rotated wrong?
Old Mar 26, 2008 | 10:14 PM
sle418's Avatar
same problem as my friend in his red ek
Old Mar 26, 2008 | 10:16 PM
monkey_boi's Avatar
Default Re: help me (sle418)
help me out people thanks and has your friend found the issue
Old Mar 26, 2008 | 10:24 PM
jdmdc213's Avatar
Alignment?????
Old Mar 26, 2008 | 10:26 PM
monkey_boi's Avatar
Default Re: help me (jdmdc213)
the ailgnment is good the car is stock !!!
and when i mean stock i mean stock check out the secondary link that says help me fix mah da
Old Mar 26, 2008 | 10:28 PM
Sleepy0132's Avatar
Banned
BUMP someone help him out, give more info on it
Old Mar 26, 2008 | 10:30 PM
sle418's Avatar
well if i get any news ill know where to find you
we just got use to the noise
Apathy47's Avatar
Default Re: help me (Sleepy0132)
did you post this in the Integra thread? they usually answer questions relating to technical issues and solutions.
Old Mar 26, 2008 | 10:33 PM
mannyman2's Avatar
Default Re: help me (Apathy47)
wheel bearings probably
Old Mar 27, 2008 | 05:02 AM
lmike6453's Avatar
is the car lowered at all? if not i would check the wheel bearing and axel
Old Mar 27, 2008 | 05:42 AM
monkey_boi's Avatar
Default Re: (lmike6453)
i will check that thanks people anything else that it may be anyone once again you can hear it in the cab only
Old Mar 27, 2008 | 10:37 AM
95teg_ls's Avatar
Default Re: (monkey_boi)
does it sound like its coming from the speakers at all? it could be interference from the alternator or a bad ground to the radio. i used to have a humming in my car, it was from interference from the cigarette lighter (using a satelitte radio)
Old Mar 27, 2008 | 10:53 AM
steveteggy92's Avatar
Default Re: (95teg_ls)
Fender well could be rubbing, part of the sheet metal can come loose and rub, seen that a few times. is it a Hum you can hear, or a hum you can feel? Or both.
The firsr thing that came to mind when I read this thread was to respond...
"Thats your motor"
Old Mar 27, 2008 | 11:02 AM
ilovemyeg's Avatar
Default Re: help me (mannyman2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mannyman2 &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearings probably</TD></TR></TABLE>x2
Old Mar 27, 2008 | 04:47 PM
monkey_boi's Avatar
Default Re: help me (ilovemyeg)
naw it is in the cab only this weekend i am lifting the car and taking the tires off
to check and no it is not coming from the rear speakers it has none but lots of people are stating that it could be the wheel bearing if one exist .
Old Mar 27, 2008 | 10:11 PM
monkey_boi's Avatar
help people help
Old Mar 28, 2008 | 12:14 AM
kra95teg's Avatar
could be road noise from the tries on the ground....all integras let in some road noise...
wheel bearing would sound like a knocking not a hum
if it is lowered it can rub on the inner fender and make a vibration up the steering rack.
but i think it could be road noise...
what psi are your tires set @
also these are just trouble shooting options not the real answer...so if you post up what you have done or going to do it will take sumthings off the list....
Old Mar 28, 2008 | 03:30 PM
monkey_boi's Avatar
Default Re: help me (kra95teg)
car is not lowered car is at the tire pressure recomended 35-40psi car again is not lowered i raised the car and it does make noise when turning the tires took off tires and need new brakes of course
and rotors as well man this car sucks damn
Old Mar 31, 2008 | 04:04 PM
monkey_boi's Avatar
i still need help
Old Apr 1, 2008 | 05:48 AM
lmike6453's Avatar
is it at at least 35 psi when the tires are cold?
my rear makes a waterfall sound when it rains because i drilled a hole under the spare tire so water leaking in could get out
did you try to adjust the ebrake cable?
how many clicks does it take when you pull on it to grab tightly?
Old Apr 1, 2008 | 10:14 PM
monkey_boi's Avatar
i never counted that but that would be a good idea hmm i think it make 7-10 clicks which i think is the normand the tires are at specs of what the tires do ask which is 35psi
Old Apr 2, 2008 | 07:52 AM
lmike6453's Avatar
yea anything below 6 is technically too tight...i have min where it gets tight enough to hold the car in place after 10 clicks....
Old Apr 2, 2008 | 07:53 AM
lmike6453's Avatar
and i jus remembered another thing that can be making that noise is the brake caliper rubbing on the rotor...to check jack up the back side of the car and take off the ebrake with the car in reverse so it cant roll forward...
then spin by hand both tires and see if one has alot of drag
