help me!!!
Sorry I accidently hit the enter button before and it posted something else
Sorry guys!!
I have a da with a b16. I think the timing belt broke on me...the car shut off and won't turn on...I'm gonna make sure today when I get home, but my question is...
Is it true that if your timing belt breaks it can mess up the valves, therefore messing up your whole head?
Sorry guys!!
You have to be kidding me...you know everyone's going to ask for more info.
So give us more info and then we'll help you.
-- Kevin
Edit*Ok well seems you changed around your post so now it makes more sense (more info), as mine doesn't any longer.
Modified by b62pteg#2 at 7:38 PM 4/16/2006
-- Kevin
The answer is yes it's possible.
I highly suggest NOT trying to start your car. Take everything off you have to to check on your belt.
If you don't know what you're doing... tow it to a shop.
-Rik
-Rik
To keep the answer simple and just to answer the OP's question....
Snapping a timing belt can POTENTIALLY cause very serious problems. "Messing up your valves or your whole head" is one of them.
A very easy way to check for a snapped timing belt is to just remove the valve cover and look.
loclowd
May 7, 2003 11:02 AM
