!! HELP!! ITR SWAY !!HELP!!
Old Oct 11, 2005 | 04:09 PM
DC4RS Integra's Avatar
Default !! HELP!! ITR SWAY !!HELP!!
The local junk yard told me that they have couple of set of ITR Sway bar for sale but it is all mixed up in there with other sway bars, and i dont have a clue of how does it look like, does any one have pix of the ITR front and rear sway bar, not mounted on their car??? it would be super helpful.
and does any1 know the measurement of sway bars for integra RS, GSR, and type R?
Thanks
Old Oct 11, 2005 | 05:02 PM
nickG's Avatar
Default Re: !! HELP!! ITR SWAY !!HELP!! (Integra SiR-G)
they will be larger than the non itr sways....
i *think* the itr rear is 22mm....i also *think* that is the diameter....
Old Oct 11, 2005 | 05:27 PM
The Droogan Leader's Avatar
Now with ultra-violence!
Default Re: !! HELP!! ITR SWAY !!HELP!! (nickG)
I believe the ITR Sway Bar has a different paint marking on it...
EDIT:
USDM ITR Rear Sway: 22mm
JDM ITR Rear Sway: 23mm
Old Oct 11, 2005 | 05:30 PM
95lstegman's Avatar
Default Re: !! HELP!! ITR SWAY !!HELP!! (Shin-tegra)
USDM and '96-'97 JDM ITR rear sway = 22mm
'98+ JDM ITR rear sway = 23mm
so you're not going to find the 23mm too often. and the difference isn't very big either, so don't sweat it. the 22mm is more than enough to neutralize the car's handling. and yes, it's almost twice the thickness of the non-Type-R sway bars. BTW at the stealership it's only like $75 or so, plus about $15-$20 for brackets and bar bushings. $100 at the stealership never went so far . . .
Old Oct 11, 2005 | 06:36 PM
thx guys, but i need actual pictures of the Bar i need to print it out and go match it at the junk yard he got like 305234234 different sway bar just stacking up there. and what about THE FRONT SWAY BAR, what is the difference between all the models?
Old Oct 11, 2005 | 08:40 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Here a pic:
Old Oct 11, 2005 | 11:47 PM
RicharDC4's Avatar
if they are mixed in with like random bars from civics and other integras, i believe that the ITR ones will be substantially bigger. and you will know.
Old Oct 11, 2005 | 11:55 PM
LSvtec03's Avatar
Default Re: !! HELP!! ITR SWAY !!HELP!! (RicharDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicharDC4 &raquo;</TD></TR><TR><TD CLASS="quote">if they are mixed in with like random bars from civics and other integras, i believe that the ITR ones will be substantially bigger. and you will know.</TD></TR></TABLE>
Old Oct 12, 2005 | 05:19 AM
GSRintegra_Bob's Avatar
usdm is 22mm and jdm is 23... if you buy either one of these you will have to get a beaks kit
Old Oct 12, 2005 | 05:34 AM
Racermech's Avatar
Default Re: (GSRintegra_Bob)
the bars look the same, i had my LS and ITR bar next to each other and they looked the same to me, only difference is the size. Even then the end link bushing is the same size.
If you get the ITR bar make sure you get the ITR bushings and caps.
Your other option is to jsut buy the entire thing mew from the dealer. I paid less than $100 and i made my own beaks/BSQ kit.
Old Oct 12, 2005 | 06:21 AM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRintegra_Bob &raquo;</TD></TR><TR><TD CLASS="quote">if you buy either one of these you will have to get a beaks kit</TD></TR></TABLE>
The ITR rear sway bar does not bolt up to RS, GSR or LS Chassis. The unibody construction is different.
Old Oct 12, 2005 | 07:09 AM
Micha's Avatar
FAILWGN
Default Re: (98 Spec R)
are you saying a Type R rear sway wont work on a non-type R car? I am just trying to not be confused. Thanks. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">
The ITR rear sway bar does not bolt up to RS, GSR or LS Chassis. The unibody construction is different.</TD></TR></TABLE>
Old Oct 12, 2005 | 07:35 AM
98 Spec R's Avatar
Default Re: (Blu99teg)
The mounting locations are different on the sub frame. The ITR has a completely different rear lower subframe and sway bar mounting position. The ITR swaybar can bolt up with a mounting kit, the beaks kit is the most popular one.
Old Oct 12, 2005 | 07:38 AM
98 Spec R's Avatar
Here is their website. http://www.beaksproducts.com/S...t.htm
Old Oct 12, 2005 | 07:46 AM
StevieB18c's Avatar
I believe that the USDM non-r-integra comes stock with a 14mm sway bar and the USDM-R comes with a 22mm and the JDM = 23mm. Definately a great upgrade. The difference is unmistakable compared to the type -r ones. IMO you cannot feel any difference between the 22(which I have on my car) and the 23( my boy has) riding in both leads me to the conclusion that you can't feel 1 mm but hey you can say mine is bigger than yours !
Old Oct 12, 2005 | 07:52 AM
StevieB18c's Avatar
Default Re: (StevieB18c)
oh yeah you need a beaks or bsq kit to mount. I personally went with the bsq kit and then you need to do a little drilling and some itr bolts(well any bolts that are the correct length) and youve got yourself a stiffer backend.
Old Oct 12, 2005 | 08:50 AM
BSQ's Avatar
BSQ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">are you saying a Type R rear sway wont work on a non-type R car? I am just trying to not be confused. </TD></TR></TABLE>
You can go to my website at http://www.geocities.com/bretq....html (mirror site at http://www.geocities.com/bretq....html) for complete step-by-step instructions (with photos) for installing the ITR rear swaybar. My website also contains a full parts list with part numbers.
You will need a mounting/reinforcement kit to properly mount the ITR rear swaybar on the subframe. You can go to http://www.geocities.com/bretq/mounting_kit.html for further information (or my mirror site at http://www.geocities.com/bretq2/mounting_kit.html).
Let me know if you have any other questions or concerns. I will be glad to help you out.
Old Oct 12, 2005 | 09:33 AM
gsrclan's Avatar
Default Re: (BSQ)
It's one of the best and simple mods you can make. I installed one on my 97 GSR with BSQ kit about 3 yrs ago, still working great.
Old Oct 12, 2005 | 10:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You won't need a front ITR swaybar. They are the same size as GS-R front bars, and the same size as later LS front bars (24mm). Earlier LS's had a 22mm front bar.
Old Oct 12, 2005 | 01:44 PM
spender1326's Avatar
What's the name of the junk yard in el monte. I want the front ITR bar. I already have rear USDM ITR 22mm one on my 94 ls with a 22mm front. This probably means neutral to slight oversteer. I need a bigger front sway to get more neutral. Thx.
Old Oct 12, 2005 | 03:25 PM
Default Re: !! HELP!! ITR SWAY !!HELP!! (spender1326)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spender1326 &raquo;</TD></TR><TR><TD CLASS="quote">What's the name of the junk yard in el monte. I want the front ITR bar. I already have rear USDM ITR 22mm one on my 94 ls with a 22mm front. This probably means neutral to slight oversteer. I need a bigger front sway to get more neutral. Thx.</TD></TR></TABLE> Jay's on alpha street
and thanks guys i look moer into the reforcement kit, i think i going to go with the ASR SRK.
Old Oct 12, 2005 | 05:09 PM
Cliffjumper2's Avatar
the jdm 98 spec 23mm itr rear sway is 19% stiffer than the usdm 22mm itr rear sway
so it does make a difference.
Plus, you can pick them both up for about the same price.
GSR-REX
Sep 7, 2010 06:28 PM
nw dc two
Jan 7, 2007 01:59 PM
Aquafina
Suspension & Brakes
Sep 8, 2005 11:38 AM
sol badguy
Apr 15, 2004 08:49 PM
riceball777
May 18, 2003 05:44 PM
