Help!!!! Integra throwing out multiple codes and running terribly.
Old Jun 19, 2009 | 09:17 PM
houstonteamer's Avatar
Default Help!!!! Integra throwing out multiple codes and running terribly.
First off the car is a completely stock 98 integra ls. Previously i have had problems with misfiring so i have changed spark plugs this month already, however when my girlfriend was driving down to SD from Santa Barbara the CEL began blinking I pulled the codes and this is what i got.
1 O2A - Oxygen sensor #1
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
Please help ASAP.
Old Jun 19, 2009 | 09:25 PM
theazndog's Avatar
Default Re: Help!!!! Integra throwing out multiple codes and running terribly.
Please help ASAP.
ecu problems
Old Jun 19, 2009 | 09:31 PM
so youre saying that since my ecu is bad it causes all this and makes it run bad?
Old Jun 19, 2009 | 10:07 PM
theazndog's Avatar
possibly. man
Old Jun 19, 2009 | 10:19 PM
nihad's Avatar
Disconnect the battery wait a min then hook it up and check them again it could be some thing stupid... But if nothing you will have to start chaning one by one... That fluction crank sensor could be bad maybe that why its saying its misfiring... There is a mod you can do to delete that sensor then you dont have to worry about the misfiring...
1badteg
Feb 23, 2010 01:52 PM
skUnK2jdm
30
Feb 5, 2008 11:00 AM
99spanishGT
Mar 11, 2004 07:07 AM
