help! intake :)
Old Oct 25, 2008 | 09:10 PM
DaredeVo's Avatar
Default help! intake :)
so i just got my 96 acura integra and i want to get a intake but dont know which one i should get. i was thinking of getting a long ram, but i'm from Pennsylvania and do you guys have any suggestions? thanks.
Old Oct 25, 2008 | 09:15 PM
Jimmy's Avatar
Global Moderator
IMHO.. an intake is an intake.. i wouldn't pay a whole lot of money for a name brand intake.. just pick up a short ram off of ebay or here in the marketplace.. I would make sure you get a good filter at least though.. such as k&n, etc.
Also i would avoid going with a cold air intake.. not worth the chance of being caught out in the rain running thru some big puddles and sucking up water and hydrolocking your engine.
Old Oct 26, 2008 | 05:29 AM
felixjr18's Avatar
Default Re: help! intake :) (DaredeVo)
I've have an ebay cold air intake on my DA and as far as water goes im not too worried because it lituarrally has to be dipped in water from what i've been told plus I have a spare short jus in case...
Old Oct 26, 2008 | 05:35 AM
kronikSLOW's Avatar
Default Re: help! intake :) (felixjr18)
stock air box is as good as it gets cold air is going to draw air from where your stock box already does and its going to be harder to clean the filter. soo spend 100 bucks and by a k&n air filter and call it a wrap.
Old Oct 26, 2008 | 05:59 AM
felixjr18's Avatar
Default Re: help! intake :) (kronikSLOW)
$100.00 for a k&n filter?
Old Oct 26, 2008 | 07:41 AM
hollums2k's Avatar
just get an AEM shortram...they look good for show and they do their job. i think about $120 bucks, maybe cheaper...comes with a decent cone filter.
Old Oct 26, 2008 | 08:11 AM
BoSox46GSr's Avatar
Default Re: (hollums2k)
EBAY intakes FTW. Cheap and it does it's job. Mine was like $25 at most. No problems with it yet.
Old Oct 26, 2008 | 08:28 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kronikSLOW &raquo;</TD></TR><TR><TD CLASS="quote">stock air box is as good as it gets cold air is going to draw air from where your stock box already does and its going to be harder to clean the filter. soo spend 100 bucks and by a k&n air filter and call it a wrap.</TD></TR></TABLE>
Do you even know where your stock air box draws air from???
And $100 for a kn filter???
You got ripped off.
Old Oct 26, 2008 | 08:41 AM
omnirage's Avatar
Read the tons of boring threads on intakes, or just read about intake length/diameter and what powerbands they support.
I'd reccomend a long ram/cai. Don't worry about the waterlocking issue, just use your brain and turn the tube into a two piece intake. Get coupler and be done with it.
Then you can also satsify those who think a short ram is better for a stock ls
Old Oct 26, 2008 | 02:40 PM
t i cl u s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hollums2k &raquo;</TD></TR><TR><TD CLASS="quote">just get an AEM shortram...they look good for show and they do their job. i think about $120 bucks, maybe cheaper...comes with a decent cone filter.</TD></TR></TABLE>
Is K&N's Air Filter better than AEM's?
Old Oct 26, 2008 | 06:05 PM
The G2 Racer's Avatar
Default Re: (t i cl u s)
I don't like Oil based filters like the K&N.
AEM uses a dry flow filter now.
Amsoil has nice filters too.
Old Oct 26, 2008 | 06:46 PM
majinsoftware's Avatar
I have a cold air intake and the filters been dipped in water a few times. It wont suck up water unless its completely submersed. Air is easier to suck up then water so aslong as theres enough surface not under the water it will suck the air instead.
Old Oct 26, 2008 | 07:55 PM
kronikSLOW's Avatar
Default Re: help! intake :) (omnirage)
100 bux i dont know i bought mine 3 years ago probably paid 75 but hey close enough. and yes the stock air box draws air from the wheel well last time i checked whens the last time you checked.
Old Oct 26, 2008 | 08:12 PM
lilvietboy's Avatar
EBAY FTW
worst thing i've heard from e-bay intakes my friend took his out and dropped it and it cracked it and then he just cut it and what not and put it back into his car and made it into a short ram XDD
Old Oct 27, 2008 | 06:06 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kronikSLOW &raquo;</TD></TR><TR><TD CLASS="quote">100 bux i dont know i bought mine 3 years ago probably paid 75 but hey close enough. and yes the stock air box draws air from the wheel well last time i checked whens the last time you checked.</TD></TR></TABLE>
The tube loops back up to next to the airbox coming out of the fender. If you have abs its right next to it in the fender... It still draws air from inside the engine bay.
Old Oct 27, 2008 | 10:21 AM
Rajin's Avatar
Default Re: help! intake :) (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">
The tube loops back up to next to the airbox coming out of the fender. If you have abs its right next to it in the fender... It still draws air from inside the engine bay.</TD></TR></TABLE>
Ding Ding Ding, why you have to remove all the stock air box components when you buy a CAI.
Old Oct 27, 2008 | 10:40 AM
choji's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kronikSLOW &raquo;</TD></TR><TR><TD CLASS="quote">and yes the stock air box draws air from the wheel well last time i checked whens the last time you checked.</TD></TR></TABLE>
that's the itr resonator.
http://autopedia.com/Acura/97_TypeRintake.html
Old Oct 27, 2008 | 10:44 AM
Rajin's Avatar
Default Re: help! intake :) (choji)
DA integras also possess a resonator box.
Old Oct 28, 2008 | 03:45 AM
billabong's Avatar
Default Re: help! intake :) (Rajin)
that they do, all of that wasted plastic to quiet our engines?
Old Oct 28, 2008 | 06:09 AM
mistik_DC4's Avatar
Go to pepboys and buy a velocity stack. And then make your own filter for it. Or u can buy BLOX velocity stack with filter. A lot cheaper and works better than any ebay intake.
Old Oct 28, 2008 | 06:20 AM
AWD Terror's Avatar
Default Re: help! intake :) (mistik_DC4)
Spent $18 off ebay for a short ram. Why spend all that money for maybe a few horsepower?
Plus I knew I was working on getting parts for my build at the time, so I knew I would only be using it for a short time.
Old Nov 4, 2008 | 08:44 PM
DaredeVo's Avatar
wow, thanks guys. greatly appreciated ^_^
Old Nov 4, 2008 | 11:46 PM
redGSRguy's Avatar
Default Re: (DaredeVo)
Get the Mugen, if you can't afford it get a Comptech and if you can't afford that get an AEM CAI. Don't bother with the V2.
wilsonlude97
Dec 24, 2008 09:35 AM
G_seven
Acura TSX
Jan 31, 2008 09:50 AM
Mikizzle
Dec 11, 2003 12:28 AM
1 Special CTR
Oct 26, 2002 12:28 PM
1997exciv12w3
Oct 21, 2002 11:31 PM
